Missing fuses? Recovered stolen '90 4WD 3VZE MT deluxe pickup won't start
Old Oct 18, 2021 | 09:04 PM
plainjane's Avatar
Halp!
The clock has started in the tow yard for my truck in SF, which won't start with a jump. I noticed that the fuse box cover is missing, and can't identify what I need with the factory service manual. I can't find a copy of the owner's manual either. Which fuse(s), if any, should I replace to get the truck out of the tow yard?
Thank you Yotatech Angels..
Old Oct 19, 2021 | 12:19 PM
2ToyGuy's Avatar
Here's a picture that should help a little. If you need, I can post a schematic diagram too, but I think this should do the trick for you.
Ignore the little red markings, they were for another thread.
The two missing regular, normal sized, automotive fuses are spares. Put in one of whatever you want in them. They have no metal clips or wires going to them.
IIRC, the large fuses, that Toyota calls fusible links, are attached on the bottom of the fuse box. It comes out easily. The wires are under there too, so make SURE the battery cables are off before working on the fuse box! No arc-welding allowed!
Good luck to you. Glad you got your truck back!
Pat☺
Old Oct 19, 2021 | 04:42 PM
plainjane's Avatar
I showed your photo to the parts store and it worked. You rock!
Old Oct 20, 2021 | 10:26 AM
2ToyGuy's Avatar
Glad i could help out a little!
Pat
92ext3.0
Mar 27, 2021 07:51 PM
Jeremyks
Apr 11, 2019 04:35 PM
bfett22
Apr 18, 2013 09:47 AM
ranger_t_f_u
Dec 26, 2012 06:28 PM
