Marlin Crawler Bumper Help
Old Dec 4, 2009 | 11:22 AM
nick1990's Avatar
Ok so got my bumper all painted, 3 day process because of rain.
So today i finlay got to remove the factory bumper finaly after and hour or so, i then get my MC bumper too put and well it dosent fit =(...the side support mounts on the bumper are off 1\4"...there to close to togather, not far enough to fit on the frame.
Any one have any tips to what i can do, the only thing i know to do is cut one of the support mounts off and bolt it on and the re-weld the one mount back onto it
thanks
Old Dec 4, 2009 | 11:54 AM
muddpigg's Avatar
Did you tell them the year of the truck? if so are you tightening the mounting hardware as you go or just getting them started?
If the above doesn't help Marlin has a product support section on the forumn. Post up with pics.
Or call them
Or both
Old Dec 4, 2009 | 04:37 PM
nick1990's Avatar
GOOD NEWS!!!...ITS ON =)...just had to bend the mounts just a bit, and they slid rite on....
with all that said and done, just i torque the bolts???...if so how much
Old Dec 5, 2009 | 03:37 PM
943kgt's Avatar
just tighten them as hard as you can!
Old Dec 5, 2009 | 03:52 PM
kawasakimoto_7's Avatar
yeup i had the same problem pics?
heres mine
Old Dec 5, 2009 | 04:09 PM
Jay351's Avatar
I was just gonna say, Use a pry bar and bend that sob on.
Tighten the bolts tight.
Old Dec 5, 2009 | 04:24 PM
Tubbyfatty's Avatar
I also hear you should do a small weld on the back, a vertical weld on the frame and bumper.
x2 for pics
Old Dec 5, 2009 | 04:49 PM
shaeff's Avatar
http://imgur.com/QxfnYl.jpg
heres mine
So clean! Stupid NE road salt has killed my body panels.
Old Dec 5, 2009 | 05:56 PM
dropzone's Avatar
Fossilized
you are correct about the small bead...if not the bumper will go up or down if used as a recovery point...mine is now welded
justdifferentials
14
Jun 11, 2017 08:36 PM
mxdw88
Sep 20, 2015 03:13 AM
AkitaDog
Sep 3, 2015 09:01 PM
BigMike
Marlin Crawler
Sep 3, 2015 07:49 PM
