Manual Transmission Front Seal Leak. Will Leak Stop Work?
Old Aug 15, 2006 | 07:42 PM
JNetTrecker's Avatar
Question Manual Transmission Front Seal Leak. Will Leak Stop Work?
I have a 1994 Toyota truck w/ a 5 speed manual that the front seal is leaking. Is there an additive or stop leak you can add to the oil to temporarily fix the problem? I just got rear ended the other day and my neck an back are messed up so I will not be able to pull the tranny right now.
Suggestions please...........
Old Aug 15, 2006 | 07:52 PM
dwh91102's Avatar
If its not leaking that bad, just be sure to keep it full of fluid, untill your able to pull the tranny and fix the leak. I recomend staying away from anykind of stop leak.
Old Aug 16, 2006 | 04:05 AM
Flash319's Avatar
I agree. I had the same thing on my truck and let it go for a while then my clutch was screwed because the oil gets on the plate. I would just drive until you can pull the trans. Don't be surprised if you have to put a new fiber clutch plate in though.
Old Aug 16, 2006 | 04:16 AM
It is pretty bad. What about something like “barsleak for oil”? I think the viscosity of the transmission fluid would screw with stuff.
voiddweller
19
May 2, 2016 09:10 PM
94whiterunner
Sep 22, 2015 07:25 PM
ACZR
Jun 23, 2015 07:55 PM
gog1968
Jun 22, 2015 05:55 AM
