Manual Transmission Front Seal Leak. Will Leak Stop Work?
I have a 1994 Toyota truck w/ a 5 speed manual that the front seal is leaking. Is there an additive or stop leak you can add to the oil to temporarily fix the problem? I just got rear ended the other day and my neck an back are messed up so I will not be able to pull the tranny right now.
Suggestions please...........
I agree.
I had the same thing on my truck and let it go for a while then my clutch was screwed because the oil gets on the plate. I would just drive until you can pull the trans. Don't be surprised if you have to put a new fiber clutch plate in though.
voiddweller
19
May 2, 2016 09:10 PM
FS[PacNorWest]: T100 auto trans/tcase - Bay area, CA
94whiterunner
Sep 22, 2015 07:25 PM
