Making a Vacuum Pump
Does the vacuum on the AC need to be a slow 1? Local Autozones around here do not offer it on there loan list, like i have saw some people say.. I know several people working on there AC's and want to pull a vacuum. I was curious if i could make a pump. I have a couple old Ford AC pumps. They suck from 1 side and blow on the other. I have a couple electric motors. I could mount them on a 2x6 and hook to the suction side. but it would be quick , prolly 10 or 15 seconds would have it down to 30. I like making my own stuff like that but didn't know if there was a reason that it needed to be a slow vacuum?
If you want to slow it down, you could add a valve on the suction side of the compressor you use. Start with the valve fully open when you fire up your compressor, as you slowly close off the valve, you'll slowly lower the pressure in your AC system.
Are you sure that you can get a low enough pressure to evacuate the AC system with the compressor you're going to be using?
inches in mercury, inhg, does not mean you have pulled a good vacuum, you need a micron guage to properly do it, and that means holding a vacuum at less than 500 microns for at least 15 minutes after the pump is shut off. but anyway, i've pulled vacuums with a compressor out of a fridge.
I purchased one of those harbor freight air operated vacuum pumps, actually all it is is a little venturi in a big package. I purchased one to try when I was vacuum forming Lexan windshields for recumbent bicycles. It worked marginally. 28.3 inhg is equivalent to 13.90psia. What pressure are you trying to reach? Take a look at McMaster Carr (click here) and you can pick a wide range of options. You need to know what your air compressor specifications are with respect to volumetric flow rate at a given pressure. With that information, you can find a venturi that will fit your needs.
Sep 4, 2015 09:27 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
TokyoD23
Jul 12, 2015 06:01 AM
