Main Ground Fell Off, Blue VSV, and AFM questions
Old May 8, 2011 | 03:16 PM
  #41
meisentones's Avatar
You said your check engine light is not on, but try this. Try to pull a code with the paper clip. If the check engine light flashes constantly, then it tells you no code. If it is flashing, tap on the AFM to see if it stops flashing, or if does not flash at all it probably is the AFM. I had the same problem, and what I found is that a short in the AFM will cause it to not start in addition to not allowing you to pull the code. When mine went out, I could tap on the top of it and sometimes it would let it crank. If I got it running, I could tap on the AFM and it would die.
Good Luck!
Old May 8, 2011 | 08:24 PM
  #42
rusty1891's Avatar
have u checked the timing? u can throw a timing light on it while somebody cranks it over.
i had a problem like this. it would just about fire then nothing and ended up the timing was screwed
Old May 11, 2011 | 10:40 AM
  #43
Rustycan's Avatar
Turns out that the cold start injector was stuck open, and now its only running on 3 cylinders
mtb_taco
Oct 5, 2015 04:36 PM
crashburnoveride
Aug 28, 2015 09:20 PM
coffey50
Jul 28, 2015 10:55 AM
PlayAwhile
Jul 20, 2015 11:36 AM
mYnAmEiSmUd
Jul 20, 2015 06:48 AM
