LSPV bleeding (rusted bleeder valve)
Old Feb 2, 2008 | 07:35 AM
PCE91V64x4's Avatar
Anyone have any tricks for opening up the bleeder screw on the LSPV other than the usual, lots of PB blaster (I do not want to use a torch so close to the rubber piece).
I do not want to do any brake work until I know I can get all the bleeders open.
Thanks,
Scott
Old Feb 2, 2008 | 07:59 AM
jason191918's Avatar
Is it rounded off, or are you afraid of breaking it off? If it is just rounded off/rusted oversize, you could use a Vise Grip to get it off then just buy a new one.
Old Feb 2, 2008 | 08:06 AM
shaeff's Avatar
my guess is that it's seized. lots of PB blast, use a pick to try to remove any corrosion from around where the threads meet the LSPV. maybe a tiny amount of heat, but that's not good as you *could* boil the brake fluid, thus removing it's hydraulic properties. (as in, it'll compress- which is bad)
get yourself a good set of metric flare wrenches. rock it back and forth, and don't rush it. it's like foreplay.
Old Feb 2, 2008 | 11:27 AM
PCE91V64x4's Avatar
I was afraid of breaking it. After soaking it and letting it sit for a while I went and it opened up just fine with a socket wrench. At first I was using the midget 10mm wrench but when I moved up to a 10mm socket wrench that took care of it.
There was tons of air in the LSPV and now my brakes are great.
edoyle12
11
Mar 20, 2017 02:26 AM
Sep 4, 2015 09:27 AM
Luvmeye22re
Aug 4, 2015 03:53 PM
87turboPA
Jul 12, 2015 07:49 AM
87turboPA
Jul 9, 2015 05:58 AM
