LSPV Bleeding
Old Apr 3, 2010 | 12:15 PM
DanStew's Avatar
LSPV Bleeding
I am bleeding the brakes and I will bleed the proportion valve. My question is.
I do not see a "bleed screw" like the brakes, but there is a bolt under the bleed nipple on the LSVP. I see not way to turn the nipple to bleed thebrakes and when i turned the bolt i did get fluid to come out. I am guessing this is the way to bleed the LSPV. Am I correct? I have not seen any real pictures of others showing the way to bleed it, i jsut want to make sure.
Thanks!
Old Apr 3, 2010 | 12:31 PM
yotaman85's Avatar
mine has a bleeder screw.
Old Apr 3, 2010 | 12:51 PM
DanStew's Avatar
Well I used it anyway. It did bleed from there. Lets see how it goes. It has some PSI coming out of that bleeder.
Old Apr 3, 2010 | 12:52 PM
xxxtreme22r's Avatar
factory bleed screw might be topped with a rubber cap look for that.
Pri$erulz
Nov 17, 2019 08:03 PM
4.34runner88
Feb 7, 2016 02:24 AM
Scatterbrain
Sep 27, 2015 08:24 AM
scheuvront1993
Sep 17, 2015 06:17 PM
old87yota
Sep 9, 2015 12:39 PM
