LSPV Bleeding
LSPV Bleeding
I am bleeding the brakes and I will bleed the proportion valve. My question is.
I do not see a "bleed screw" like the brakes, but there is a bolt under the bleed nipple on the LSVP. I see not way to turn the nipple to bleed thebrakes and when i turned the bolt i did get fluid to come out. I am guessing this is the way to bleed the LSPV. Am I correct? I have not seen any real pictures of others showing the way to bleed it, i jsut want to make sure.
Thanks!
Thanks!
