Low fuel light won't come on
Old Jul 12, 2009 | 08:58 AM
dboatrig's Avatar
The low fuel warning light in my '90 v6 truck no longer comes on when it should. The light glows when put voltage across the terminals, so I know it's not the light itself that is faulty. The fuel level gauge works normally. How can I fix this warning light?
Old Jul 12, 2009 | 02:43 PM
TNRabbit's Avatar
Mine hasn't worked since 1999....
Old Jul 12, 2009 | 02:58 PM
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
My '91 4runner SR5 has all the bells and whistles.....EXCEPT that.....lol!
Trace the wiring. Maybe you have a break somewhere. Are the contacts clean?
Old Jul 12, 2009 | 03:23 PM
PlugItIn's Avatar
i wouldn't worry about it...shouldn't let the tank get that low anyways, bad for your pump
Old Jul 12, 2009 | 03:39 PM
Jay351's Avatar
x2, fill when you're at a 1/4 tank, thats what I do
Old Jul 13, 2009 | 04:13 PM
Flash319's Avatar
I never knew that was an option on these trucks.
Old Jul 13, 2009 | 09:49 PM
dboatrig's Avatar
Yup, little orange rectangular light just left of the E, that you can't see until it comes on. I guess 20 years of letting the tank run to less than 1/4 full has burned up the part of the sender that triggers that light. I'd like to fix it, so I'll keep looking. Thanks.
Old Jul 14, 2009 | 04:26 AM
Flash319's Avatar
According to the FSM the light is run from the sender in the tank and not the actual gauge in the dash. They are 2 different circuits so your sender unit has probably gone bad. You can test it but you have to get to the plug. Terminals 1 and 4 on the sender plug are the light switch.
Old Jul 14, 2009 | 09:04 AM
Erik Beeman's Avatar
I've got it on my 88 and 92, and neither of them work either.
Old Jul 14, 2009 | 10:11 AM
Blurr's Avatar
mine came on yesterday! d'oh
smthwsn357
May 1, 2024 07:28 AM
Charecter1
Nov 6, 2023 10:08 AM
jbv808
Aug 6, 2021 04:47 PM
Sep 4, 2015 09:27 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
