Low Compression After Rebuild
Old Sep 14, 2013 | 04:49 PM
  #61
Kiroshu's Avatar
OEM fuel injectors...
Old Sep 14, 2013 | 07:19 PM
  #62
big bear's Avatar
Originally Posted by osv
so it probably wasn't the injectors... you could measure the fuel pressure with a gauge... excessive fuel pressure won't hold the injectors open, but if it's too high it'll send more fuel in when the injectors are opened... 3vze is a narrow-band O2 sensor? can a narrow-band sensor compensate for that situation as well as a wide-band O2 sensor can?
on a 22re, I think that the afm can be adjusted to richen the fuel mixture over the entire operating range of the engine... so i'm wondering of there is an afm problem on your 3vze that is doing the same thing? you should be able to check the afm with a multimeter.
black smoke is gas, blue smoke is oil, white smoke indicates moisture...
It's fuel smoke for sure.
Flamethrowers.
Old Sep 14, 2013 | 07:25 PM
  #63
Kiroshu's Avatar
Get OEM injectors.
Old Sep 15, 2013 | 06:30 AM
  #64
big bear's Avatar
Get OEM injectors.
What brand of injectors do you run ?
Old Sep 15, 2013 | 05:40 PM
  #65
maachine's Avatar
you sure its an injector problem? i'd think after 2 sets of working injectors......someone should start looking else where. bad wiring? bad computer? bad sensors? bad fuel regulator?
Old Sep 15, 2013 | 06:22 PM
  #66
Kiroshu's Avatar
I only and would only run OE Toyota fuel injectors. That's just my preference though .
Old Sep 15, 2013 | 06:26 PM
  #67
big bear's Avatar
Thanks what I was thinking.
Old Sep 15, 2013 | 06:30 PM
  #68
big bear's Avatar
I do appeciate your advice and help, but lots of guys run these injectors, if you look at the feedback from buyers on ebay people are happier than pigs in mud with them.
http://feedback.ebay.com/ws/eBayISAP...k&myworld=true
100% positive feedback
Old Sep 15, 2013 | 06:38 PM
  #69
big bear's Avatar
I was messing around with the truck this evening, one thing I noticed when I goose the throttle there is an audible loud click coming from the air filter box, I can feel it when I put my hand on the air filter box.
Should the little door in the intake box be snapping shut when I gun it ?
It was up to full running temp.
Old Sep 15, 2013 | 06:40 PM
  #70
big bear's Avatar
Fuel reg looks pretty old, thinking of putting a new one on.
Even if it's not the problem I'll still have a new reg, I plan on keeping this Runner for a long time.
Old Sep 15, 2013 | 06:44 PM
  #71
big bear's Avatar
Been searching for a full diagram of the vacuum hose routing, no luck,
anyone have an accurate diagram you could post up.
I put the hoses back like they were before dis-assembly but I can tell a Mickey Mouse mechanic had worked on it before I bought her.
Old Sep 15, 2013 | 06:46 PM
  #72
Kiroshu's Avatar
Air Flow Meter Air Door opens when the engine is running/cranking. It is a switch for the fuel pump during engine running/cranking. It could be sticky/faulty causing air fuel/ratio issues.
Old Sep 15, 2013 | 06:50 PM
  #73
big bear's Avatar
Rock sells a regulator for $56.
http://www.rockauto.com/catalog/x,ca...,parttype,6124
They sell a Beck/Arnley coolant sender for $10, the one on the truck looks mighty old too.
http://www.rockauto.com/catalog/x,ca...,parttype,4748
Old Sep 15, 2013 | 06:51 PM
  #74
Kiroshu's Avatar
Name:  66886d1176951220-3vze-vacuum-hose-diagram-reference-3vze-vacuumhose-diagram-1_zpse3aacf.gif
Old Sep 15, 2013 | 06:54 PM
  #75
big bear's Avatar
Thank you sir.
One thing I noticed, I have no check valve on the hose leading to the AS.
Old Sep 16, 2013 | 10:41 AM
  #76
big bear's Avatar
Get OEM injectors.
I do believe you were right
I think my Runner just doesn't like Flamethrowers, don't know why.
Old Sep 16, 2013 | 11:00 AM
  #77
big bear's Avatar
So here's what I did.
Pulled my old Denso's out out of the spare parts bin (the injectors were in the rig when I bought it)
Cleaned them up the best I could externally, cleaned the electrical contacts using Q-tips and purple de-greaser,then hit them lightly with some 320 wet/dry paper.
Installed them in three hours, pretty good huh, I've had some practice pulling that damn plenum off
Started right up, no eye burning smoke this time.
There was some excess smoke at start up, but went away quickly.
Checked ignition timing after she was warmed up, it was slightly off.
PVC hose clamp was kinda whimpy, replaced it with a screwdriver type clamp.
Idles better, better throttle response, more power, less smoke.
Took it for a test drive, pretty good, the motor is a dog but we all know that.
Motor go's up past 5000rpm easy, even has some low end power at 15mph in second gear.
I think it's time to take it back to the shop for it's smog check, we'll see if the cat needs replacing.
Old Sep 16, 2013 | 12:07 PM
  #78
maachine's Avatar
Glad to hear youre making progress.
Old Sep 16, 2013 | 12:42 PM
  #79
big bear's Avatar
Looks like I have a set of Flamethrowers for sale.
Old Sep 17, 2013 | 05:13 PM
  #80
Kiroshu's Avatar
Like I always say... when it comes to Toyota there is nothing like OEM parts ^_^.
Glad you finally figured it out though, very good indeed.
