Loss of trans fluid,Filling transfer box
Old Jun 8, 2011 | 03:54 AM
iselloil's Avatar
Checked my fluids before a long trip I'm getting ready to take.On my 95 toyota pickup, 22re manual trans I found that all of the trans fluid had pushed out of the trans and overfilled the transfer case. Anyone had this issue.Leave it alone or drop the transfer case?
Old Jun 8, 2011 | 04:44 AM
waskillywabbit's Avatar
You sure about that?
:wabbit2:
Old Jun 8, 2011 | 04:50 AM
iselloil's Avatar
Yes, I had drained and filled the trans and transfer case last year.Went to check the trans,down 2 quarts, no sign of external leaks.When I pulled the transfer case plug fluid just continued to pour out.It was well over the drain/fill hole.Looking at the drain pan it was a lot of fluid.
Old Jun 17, 2011 | 09:54 PM
bcg1's Avatar
There is a seal between the trans and the X-case that is leaking. needs to be changed. Before you pull out the old seal, check the installed depth and put the new seal in the same depth.
Too much fluid can drain out of the trans and cause damage. Or al easet severe in convience.
Old Jun 19, 2011 | 07:12 AM
montanatoy's Avatar
Seal
How hard is it to change this seal. I am having the same problem.
Old Jun 19, 2011 | 07:58 AM
MudHippy's Avatar
PITA level 8(10 being highest). Only because you have to remove/install the transfer case. Which sucks if you don't have a transmission jack. Most folks don't(me included). Other than that it's just like replacing any other radial-lip seal on the truck. There's a lot of fluid draining/refilling you'll need to do now too, not fun.
Old Jun 19, 2011 | 07:59 AM
bcg1's Avatar
Not too bad if you have help. I've done it w/o pulling the trans. Pull the drive shafts, shifters and unbolt the t-case from the trans and then unbolt the crossmember from the frame and pull the tcase back ath the seal is right there at the back of the trans.
Be prepared for a flood of fluid.
Old Jun 19, 2011 | 04:01 PM
Pool Playen Bob's Avatar
or drain your fluids before hand. won't be such a flood.
Old Jun 19, 2011 | 04:19 PM
bcg1's Avatar
There is a big space between the seal protected portion of the trans and the seal protected portion of the xfer case that the fluid could leak into from the trans that is not serviced by either of the drain plugs. That is where the flood would come from.
Sleaker
Aug 26, 2020 06:03 AM
Eggslinger
Jun 8, 2019 03:32 PM
the1998sr5
Jul 16, 2015 06:20 AM
Poncho0206
Jul 10, 2015 06:21 PM
crashburnoveride
Jul 10, 2015 06:39 AM
