loss of power, weird surge, 22re efi
Old Sep 5, 2012 | 07:39 AM
trktwo's Avatar
i used the search, but did not find my symptoms.
what happens is. truck starts fine, runs great. driving along in city traffic (stop and go). engine starts to stumble at idle. i rev the thottle to keep it running. engine will rev up to 2000-2500 rpm. revolutions decrease, kind of a dropping surge. truck will move, but under full throttle, or light feathering of throttle, it will only go up to 2200-2500 rpm, dropping down to 1000-1500 rpm. that goes on for maybe 4-5minutes, then truck resumes normal operation. no problems, running great. help!
Old Sep 8, 2012 | 04:26 PM
trktwo's Avatar
really, 114 views, and nobody has come across this before? somebody throw me a bone
Old Sep 8, 2012 | 04:42 PM
racerflea's Avatar
did u change anything before this occurance?
Old Sep 8, 2012 | 04:55 PM
B-Fake's Avatar
Since it sounds like it only happens during warm-up, I would suspect the AAV/IACV/Air Valve whatever you want to call it, as I think it's the only thing that affects idle at warm-up. You can put a piece of duct or electrical tape over where the hose connects to the throttle body and see if that makes a difference. You won't have the idle up during warm-up, but if it still has the hesitation it's something else. Maybe replace the O2 sensor and test the TPS and AFM.
Old Sep 8, 2012 | 08:02 PM
GDElpaso's Avatar
Also check vacuum lines, and make sure your getting fuel.
Old Sep 10, 2012 | 06:01 AM
trktwo's Avatar
thanks!!! the only things i have worked on are frontend parts, balljoints, tie-rods, and rebuilt transmission/new clutch.
i appreciate the comments, will post up results.
hesitation, much better descriptive term.
smthwsn357
May 1, 2024 07:28 AM
Sleaker
Aug 26, 2020 06:03 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
Sandman
Jul 14, 2015 12:36 PM
icentropy
Jul 14, 2015 10:23 AM
