Loose Tailgate Hinge
Old May 15, 2007 | 11:24 AM
Seans4Runner's Avatar
The hinge on my tailgate on the passenger side is making the worse noise when I hit a bump. I can pull the tailgate down and wiggle it around so it's deffinatly loose. Any ideas on fixing this? It's shaking back and forth when the gate it closed and it's super loud.
Old May 15, 2007 | 01:13 PM
TNRabbit's Avatar
There are little plastic thingys that prevent the rattling; I've seen them on ebay or you can get them from the dealer
Old Apr 19, 2009 | 10:05 AM
Geno's Avatar
I have an 88 4runner that had the same deal going on. super loud clanking against the tailgate and everything else for that matter. I dont know how long my "fix" will last but it cost me nothing and took only a few minutes to do. So if it wears out in a month or two I'll just do it again.
What I did to quiet the ruckus those hinges caused was I padded the hinges themselves. I used a layer or two of 1/8" thick foam tape (weather strip) in strategically planed areas where the hinges hit against other things. The tape itself seemed a little weak so I wrapped it all up with a layer of electric tape to make it last a little longer. Worked Great! No more annoying noise and no money spent.
Old Apr 19, 2009 | 11:06 AM
abecedarian's Avatar
Check how it comes apart then hit Home Depot or somewhere and see if they have nylon washers that'll fit on the pivot points to tighten things up.
Old Apr 19, 2009 | 11:32 AM
Jay351's Avatar
Make sure the main pivot/mount bolts are tight. The PO of my truck shoved the wrong bolt in there, and it obviously didnt tighten down all the way. That thing rattled like nobodys buisness after I removed the cheap drop in bed liner that was holding tension on it.
I got one from a member on here and it fixed my problem..
I8URSVT
Mar 2, 2021 06:23 AM
1uzRunner
63
Nov 10, 2018 03:58 PM
Davebarbier
Nov 3, 2015 03:28 PM
MaK92-4RnR
Oct 28, 2015 02:45 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
