Looking for a Speedo Gear for a 1990 4wd / 31s / 4.88s / 5 spd
Old Sep 6, 2023 | 05:45 AM
52brezelfenster's Avatar
Mornin', my speedo is off by 5-7mph at freeway speed (on the high side) compared to my GPS.
Does anyone know what speedo gear I could get to get the speedo back to accurate, or at least close to accurate?
My truck is a 1990, 4wd, 22RE, 5 speed manual. 31s with 4.88 gearing.
Thank you
Old Sep 6, 2023 | 06:41 AM
JoeS's Avatar
Mine was too. I did notice at stop the needle sat on the 5 mph mark. The needle was off. I removed the cluster cover and gently turned the needle downward to what looked like about a 0 mph spot. Hold it at the base not the needle portion. The needle just slips onto the shaft so turning was easy. Was off from the factory assembly. Now it's near dead on by GPS and by those cop stationary roadside radar speed warning devices. Worked for my situation.
If its consistently off at all speeds because of larger tires, then this needle adjustment should work.
Old Sep 6, 2023 | 07:23 AM
Thanks for the info. My needle sits at 0 when parked. Mine is off due to a gear ratio & tire size change from factory. I've read elsewhere that changing out the speedo gear can put it back to calibrated, just unsure what the # of teeth need to be.
Old Sep 6, 2023 | 11:30 AM
Discombobulated's Avatar
Years ago I came across someone that had a selection of gears depending on changes, BUT I’m worthless and can’t remember where or who it was, maybe someone will chime in.
mine is off about 5 and at this point I kinda don’t care anymore
Old Sep 6, 2023 | 01:57 PM
millball's Avatar
Might help to know how many teeth are on the gear you have now.
Old Sep 7, 2023 | 11:43 AM
aztoyman's Avatar
Your best bet might be something like these guys sell. https://www.dicksspeedotach.com/speedometer-adapters/
aztoyman
Jul 5, 2022 05:13 PM
1stgenboy
Jul 3, 2021 01:53 PM
cars-guy
Dec 13, 2016 06:41 AM
treyota
Apr 4, 2011 07:13 AM
