speedo reduction
Old Feb 28, 2011 | 12:40 PM
treyota's Avatar
speedo reduction
I lifted my '84 3" and put 33" tires on it, and I got a ticket last night. My speedometer is obviously off. I think I'm about 10 m.p.h. off. Meaning I need to lower the speedometer. Anything out there I can just swap over?
Old Feb 28, 2011 | 12:57 PM
waskillywabbit's Avatar
Go 10 mph slower.
GPS will help you know how much it's off or just drive beside someone checking their speedo that's correct.
I don't think there's an easy way to recalibrate your speedo.
:wabbit2:
Old Feb 28, 2011 | 01:51 PM
treyota's Avatar
What about changing gear ratios in the speedometer gear set? If I raise the gears it should lower the speed... Or is it the other way...?
Old Feb 28, 2011 | 02:10 PM
JonnyBoy's Avatar
You've probably got 4.10's, so at 55 mph on the speedo you're doing roughly 65 mph, 65 on the speedo is roughly 77. I don't know of any different tooth count gears for the transfer case to correct the speedo. There's always the option of changing the gears in the thirds.
Old Mar 22, 2011 | 07:37 PM
Jmitchell5's Avatar
So if u put bigger tires on are u going faster or slower than ur speedo
Old Mar 22, 2011 | 07:39 PM
Tofer's Avatar
Sponsor
regear
Old Mar 22, 2011 | 08:34 PM
corax's Avatar
lower gears + stock tires = speedometer reads faster than actual speed
bigger tires + stock gears = speedometer reads slower than actual speed
Old Mar 24, 2011 | 07:29 AM
toyotabull's Avatar
They have a speedometer reduction piece that goes between the transmission and the speedometer cable just for that. Where, and if they make it for a toyota, I don't know. But its something to look into. And here it is https://www.yotatech.com/forums/f116...l-pics-195986/
Old Mar 25, 2011 | 10:53 AM
treyota's Avatar
Speedo reduction
Thanks Bull, that was really helpful. I called Commercial Speedometer, they're sending my reduction box tomorrow.
Old Mar 25, 2011 | 12:18 PM
toyotabull's Avatar
Let me know how it turns out. I might have to get one also after I put the rebuilt motor in next weekend. I have been running 36's and 33's for 7 years now and its always been off, lol.
Old Apr 3, 2011 | 03:32 PM
treyota's Avatar
Got it taken care of. The guys down at Commercial Speedo in Sacramento were knowledgeable and very helpful. I recommend them to anyone having a speedometer issue. Thanks for all you help guys!
Old Apr 3, 2011 | 04:21 PM
89truck3point4's Avatar
have any idea what they did to fix it? i thought it was cable driven so you cant adjust it
Old Apr 4, 2011 | 07:13 AM
treyota's Avatar
For about $88.58 they built me a gear reduction box. It's about 3" x 2" and goes in line to the speedo cable. https://www.yotatech.com/forums/f116...l-pics-195986/
Dieselmann
Feb 19, 2019 02:57 AM
live4soccer7
May 11, 2016 06:52 PM
charlie_fong
Sep 27, 2015 10:06 PM
94ofCanada
Aug 14, 2015 06:37 AM
Pedalpwr27
Aug 13, 2015 06:37 AM
