lock rite in front diff
Old May 26, 2008 | 01:36 PM
weakyota91's Avatar
so i ve gota 91 toyota with 78 wagoneer axles the front is a dana 44 any ways when i first started out both diffs were welded so i ended up puttin a lock rite in the rear cause i was goin through tires too fast and it just didnt seem that safe. i was out 4byin the other day and my two front tires stopped havin power , when i got home i checked it out and my spider gears pretty much blew a part in inside. my question is what dou you guys think about putting a lockrite in front. i hated welded gears i could steer and it just made the truck drive like garbage. Does anyone have any experience with a lock rite in the front how is the sterring? i like th one iput in the rear of the truck it seems to be holdin up pretty well. Any suggestion woul d help thanks guys.
Old May 26, 2008 | 02:26 PM
DeathCougar's Avatar
any non selectable locker will cause the same problem.
You want to go ARB in the front if you want to steer.
Old May 26, 2008 | 04:27 PM
94Runner4x4's Avatar
Yea, I wouldn't go with a lunchbox if you don't want bad tire wear. x2 on the ARB, more expensive but well worth it.
Old May 26, 2008 | 07:41 PM
Beaniam's Avatar
I have a lock-right in the front and really have no problem steering. Yeah you feel it and have to adjust your driving slightly but it's not half as bad as what web wheelers make it out to be. If you have manual front hubs I say go for it. Don't leave them locked on pavement and you won't have wear and steering issues.
Old May 26, 2008 | 08:39 PM
jason191918's Avatar
An LSD is always an option too.
Old May 27, 2008 | 03:02 AM
gt0987's Avatar
I have a lunchbox locker in the front of my Jeep. It is harder to steer when in 4WD but not at all impossible. I would prefer a selectable locker, especially since I don't have manual hubs, but I'm not sure that it'd be worth the extra expense.
Old May 27, 2008 | 03:28 AM
hillbilly's Avatar
If you can't go ARB in front (which sounds like the best choice for you), then I'd go with a Detroit Truetrac.
Old May 27, 2008 | 05:47 AM
Victor's Avatar
I have a LockRight in the front. No problems steering for me. It bangs when it unlocks but always unlocks properly
jerusry
Oct 19, 2015 05:28 PM
Daneums
Aug 20, 2015 05:36 AM
PlayAwhile
Jul 20, 2015 11:36 AM
scottyg486
Jul 19, 2015 05:34 PM
TokyoD23
Jul 12, 2015 06:01 AM
