Little coolant leak on skid plate... *sigh*
Old May 18, 2013 | 09:39 PM
foppert's Avatar
Howdy all, now that i have a little time to take care of my 3vze powered 89 4runner i've got a few questions.
First and most annoying, i see a little green mixed into the caked oil on my skid plate. Almost dead center, slightly to the passenger side. I have also been losing coolant, and as far as i know my head gaskets are intact (knock on wood.) Frantically i looked for coolant lines to replace in that area and to my dismay all i can see is the water pump. Can you guys think of any easy way to deal with this? or am i in for the haul?
My truck has always leaked oil like a sieve on the passenger side of the engine, about 1 quart a month with regular driving. If i have to do the water pump should i attempt the head gaskets/cam seals which i suspect to be the source of my woes? Are there other more likely/easy suspects i can tackle?
Any other suggestions for things to replace (the truck is about to pass 250k)/ ideas on how to avoid doing a ton of work are greatly appreciated.
Old May 19, 2013 | 08:17 PM
TNRabbit's Avatar
At operating temp, have someone rev the engine & watch that area with the skid plate removed. There's a weep hole on the water pump that will drip when the seal is going bad.
Old May 19, 2013 | 08:56 PM
NickMiller's Avatar
This is how mine started, then the leak got worse, then while on my way to my uncle's house to change my water pump it seized, overheated and I had to call a tow truck... TRIPLE check it's not coming from the water pump before you drive it a bunch!
Another place it could be leaking is the upper radiator hose attachment point... (thing in the middle of the pic)... Mine leaks just a TINY bit off the skidplate from not using enough RTV when I did my water pump. (I'm too lazy to drain the radiator to fix it though)
Old May 26, 2013 | 09:48 AM
foppert's Avatar
Sorry for the long delay, i was out of town. I took rabbits advice and got the car real hot and stuck my head under while someone reved it. Nothing. I have some pretty excessive oil leaks out the cam seals and valve covers and i only saw drops of oil. Can someone point out the location of the weep hole on the water pump? The leak i have is nearly centered but more on the passenger side. From my searching the weep hole is more on the driver side? at least that is what i found searching. I still cant find the actual hole on my truck.
Blamalam
Mar 12, 2022 07:34 AM
SubiKing
Aug 21, 2021 03:57 AM
BeMiceElf
Oct 10, 2015 09:40 PM
WellsR
12
Jul 31, 2015 03:27 PM
itzmywife's
Jul 25, 2015 04:55 PM
