Light Mounting Ideas?
Old May 11, 2014 | 04:02 PM
85TurboRunner's Avatar
I think it would look better with 2 side by side or one bigger like robert m posted.
But cool nonetheless. I'm still a fan of the roundy round lights though.
Old Dec 22, 2015 | 04:00 PM
Dustin Egle's Avatar
Originally Posted by Robert m
i know its not the same but this is how i mounted my first light bar. with the 2wd grill it fit a 30'' bar almost perfect with the lower grill bar cut out.
you could probably do something similar if you put on the 89-91 grille center section.
This is an old post but how did you mount it inside the grill?
Old Dec 22, 2015 | 09:30 PM
Robert m's Avatar
My truck is 2wd and has a different grill then yours. But, to make room to sink it in, I cut out the crossbar and side sections that are in the big opening.
The actual bar is mounted to the top of the bumper.
Old Dec 23, 2015 | 11:11 AM
So you used brackets simply just faced straight down to mount it to the bumper then? Brackets off the sides of the light bar?
Old Dec 23, 2015 | 05:29 PM
  #25
Robert m's Avatar
That bar was one of the old kinds that mounted with bolts/studs from the bottom. The 4 dots you see between the bar and the top of the bumper are the mounts. I just drilled 4 holes and bolted it down.
DrZero
18
Jul 24, 2015 11:31 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
jon.r
Jul 11, 2015 03:34 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
