Leaning out at WOT
Leaning out at WOT
Anyone ever had any trouble with a 22re leaning out when you go full throttle, even though I turned the afm up 10 clicks and up the fuel pressure 10psi, somehow my wideband shows it’s still going extremely lean, tried a second afm, same result. It’s a mild stroker build, wondering if I need up go up to and aftermarket injector?
Cruise and idle it’s fine , holds 14.7, soon as I roll on the throttle it will do lean and never recover, even tried another tps and adjusted according to spec, still no good. I’ve seen people run stock computers on much more heavily modified engines, almost thinking about trying a second ecu
pcmentor
May 19, 2008 06:18 PM
