leaking backwindow
Old Jan 12, 2021 | 07:26 AM
flwoods's Avatar
leaking backwindow
1993 truck back sliding window leaking is this an easy repair to pop it out and reseal It
Old Jan 13, 2021 | 05:51 PM
Peart130's Avatar
Where exactly is it leaking?
Should be one big rubber seal holding the window to the body, easy enough to remove, shouldn't take too long.
...didnt take me too long when I locked myself out of the truck......
If not the seal then after you remove the assembly you will have access to remove/fix individual windows
Old Jan 14, 2021 | 08:39 AM
Jimkola's Avatar
YT Community Team
5 Year Member
They're pretty easy to remove. The sliding window weather-stripping isn't glued in. You'll need to fold back the rubber on the inside and work your way around. May help to have someone outside helping to pull and hold the glass as it comes out.
Old Jan 15, 2021 | 07:37 PM
flwoods's Avatar
ok thanks got this truck for the property,just rying to get it to run and fix the leak
Old Jan 16, 2021 | 07:38 AM
Jimkola's Avatar
YT Community Team
5 Year Member
If you find the weatherstrip is stiff and hard to work with you can try putting it in a large pot of boiling water for about a minute. It’ll help it regain some of it’s suppleness
Old Jan 17, 2021 | 05:27 AM
86SR5PU's Avatar
Before our auto glass guy pulls out windows that leak he looks closely at the windows weep holes.
Look at the track the window slides in. There should be holes that let water out to the outside.
If sealed closed or full of gunk water will run up and over the track to the inside.
Good Luck.
akgirl
Sep 17, 2019 06:19 AM
tikamonstr
Nov 6, 2006 07:00 AM
DaShry1
Jun 19, 2006 11:45 AM
DaShry1
Jun 14, 2006 07:52 PM
JEDI87
Nov 4, 2004 11:45 AM
