LCA replacement
Old Jul 15, 2015 | 06:43 PM
1994toyota's Avatar
LCA replacement
Ok, So I am in the process of wire wheeling the frame on my 94 22re 4x4 pickup. I noticed that the front lower control arms are pretty rusty and look they need replaced. Problem is I can;t find replacement lower control arms. Maybe my google skills are failing me tonight. Any one have a link to some new arms, aftermarket or stock oe replacement? Thanks
Old Jul 15, 2015 | 09:40 PM
Jcrawl94's Avatar
Check cl I even have 2 sets on their
Old Jul 16, 2015 | 01:44 PM
1994toyota's Avatar
Would you happen to be in Ohio?
Old Jul 16, 2015 | 04:37 PM
1994toyota's Avatar
Ok, I may have found a control arm for the truck. Now fro the fun part. While I am in there should I do the upper and lower ball joints and tie rod ends? They do not seem to have any play. I will probably do the same to both sides, then get an alignment. Thoughts? Sounds like I will probably have to get new camber bolts, sounds like I will probably cut them out if rusted to the sleeve. Thanks
Old Jul 16, 2015 | 11:37 PM
wyoming9's Avatar
Red face
Depends on what your plans are if you plan on keeping this vehicle .
It can`t hurt if you have the extra money to rebuild the whole front suspension now.
Just how bad was your LCA rusted??
I must say I looked and could find no listing for the LCA`s either for that year 4x4
Old Jul 17, 2015 | 03:03 AM
1994toyota's Avatar
There is a area about 1/2 inch by 3 inch completely rusted away.
sandyota
Feb 4, 2021 11:16 AM
mskalmus
May 28, 2017 07:51 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
rushw
Jul 18, 2015 01:46 PM
redghost.308
California SoCal
Jul 16, 2015 07:46 AM
