LC Engineering Turbo motor...disappointment??
Old Dec 24, 2008 | 12:34 PM
  #41
Erik Beeman's Avatar
Originally Posted by TOYOTA 1
theres no replacement for displacement.
Forced Induction buddy.
Old Dec 24, 2008 | 01:00 PM
  #42
scuba's Avatar
Old Dec 24, 2008 | 01:21 PM
  #43
stagger_lee's Avatar
Originally Posted by Diesel_Freak
Correct... Sort of... The 20R WAS a 2.2L, the 22R/E are 2.4L motors.
EDIT: All this talk about different motors is completely irrelevent, so what if a FHI Boxer Motor can make 500hp... it's a different motor that was designed to take that power load and flow enough air to make those numbers. A motor like the 22RE is a long stroke motor that frankly was not meant to spool up to 7K and make 400horse. Is it stong enough??? Yes, absolutely, but it was designed to be a tourquey motor, not a race engine. The money I spent to take my 1.8L 8V VW motor up to over the 200hp at the wheels (206) mark was un-real. But with all that money came high quality parts and added longevity so... There are all kinds of motors with all kinds of displacements and designs, but not all of them will do the same thing. A motor is an air pump. The faster and more efficently you can get air in and out determines your power. Everything else just modifies your powerband or your Torque curve. With that in mind, have at it.
Cheers
Dave
Relevent when simply trying to make a point that motors with little displacement cant put out high horse and torque. Point missed I guess. Just trying to defuse the v6 v8 swap crowd.
Old Dec 24, 2008 | 05:41 PM
  #44
TOYOTA 1's Avatar
lol, ok so you turbo your 4banger. then i put a blower on my big block
the point is you can do all the mods you want to a 4cyl, and an equally built v8 is gonna have more power. you don't see a 4banger racing in top fuel do you?
Old Dec 24, 2008 | 07:15 PM
  #45
I think he just wants to pull decent numbers on a 4 banger, not run high 4 sec 1/4s in his yote.
So...LCE, huh? NIce.
Old Dec 25, 2008 | 01:00 PM
  #46
LAXitives288's Avatar
Want power in a compact tuner car?: get a VW or get over it... You folks don't have a clue what Torque and power is or what it does untill I say BYE BYE in a real performance vehicle
Cheers
Dave
Yes sir, VW's are known for being "real" performance vehicles. Front Wheel Drive is also known for its sporting nature. Quit spewing ignorance. Rx7 > all
The Op wasn't asking about 8v's out of old golfs or b18's from honduhs, he wanted to know everyone's opinion on the value of an LCE turbo setup.
Old Dec 25, 2008 | 06:53 PM
  #47
Dude, no way! Tell me more =}
Old Dec 25, 2008 | 06:58 PM
  #48
Old Dec 25, 2008 | 09:35 PM
  #49
abecedarian's Avatar
Your original post said something like the dyno run showed something like 197 hp and 237 ft/lb torque at the wheels... considering stock 22re is around 110 hp and 140 ft/lb at the flywheel... I think it's fairly safe to say it's nearly a 100% increase in power after factoring in driveline losses.
I wouldn't expect it to last as long as a stock 22re though, but if taken care of it could easily hit 100,000 miles.
...for the displacement junkies... boosting an engine to 1 bar or more is a displacement increase: it's being force fed over twice the air than it would otherwise consume and a corresponding amount of fuel.
Old Dec 25, 2008 | 10:11 PM
  #50
1989toy4wd's Avatar
Im surprised none of you have mentioned the 22re's lack of efficiency. Its not a really efficient motor at all, like the other people said it was built for torque.
I dont like knocking on other people, but seriously you are going to argue that a 4cyl can make as much power as a V8 with the same mods. Get real people. Its common knowledge that it costs more money to get 400hp out of a 4cyl than a V8.
And dont get me started on hondas, subies, mitsus, etc. Yeah they can make good power, but you are also talking about DOHC motors with hemispherical combustion chambers, the 22re is a SOHC with a horrible head design, its really restictive and not very efficient as I said earlier. The most I have ever heard powerwise out of a 22re motor was 250hp, after that you are looking at custom everything, when someone gets 300hp out of a 22re it will be a miracle, and they will have a huge wallet.
Now back to LCE, they are the best out there, and the amount of time they worked on it probably amounts to that much money. They are a very good quality company! They may not make that much power but I bet if you spend 6k on doing everything yourself, you will be disappointed cause these engines just dont make that much power.
Old Dec 25, 2008 | 10:48 PM
  #51
Now thats an intelligent rebuttal I can live with.
Old Jan 9, 2009 | 11:29 AM
  #52
dark_fairytales's Avatar
here is your answer, and most people would think is close enough. http://www.vwparadise.com/content.wws?fname=racing.html
yotatech. is the place to be
Old Jan 9, 2009 | 02:12 PM
  #53
TOYOTA 1's Avatar
that thing is rude lol. but its not top fuel is it?
even if it was, it would still get blown away by a top fuel v8.
here ya go, http://www.youtube.com/watch?v=aEO9a...eature=related
Old Jan 9, 2009 | 02:20 PM
  #54
91TPU's Avatar
Originally Posted by Fofo
LC is very pricey. We can build a motor for 3k and they will charge 6k or more for it. So if your willing to do your homework you could get a nice FI set up for around 3k.
Also 190+ hp out of a 4 banger is pretty damn good. Thats near double the hp.
my si makes 197hp, plenty of n/a stock 4's that make 190hp these days, 20 years ago is a different story.
edit-this was not to take anything away from lc or the 22re, just saying, todays 4 cylinders have come a long way in terms of hp...not so much on the torque front lol
tobylab
Jan 18, 2016 07:06 PM
adammtb
Jul 27, 2015 11:57 AM
tobylab
Jul 12, 2015 12:53 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
karbin
Jul 5, 2015 11:37 PM
