LC Engineering MECHANICAL fan
Old Jun 27, 2009 | 09:11 AM
mrddk92's Avatar
Originally Posted by Plumbrbob
jizz him self LMAO
Lmao. He must be pretty stupid for wanting his plenum polished.
Old Jun 27, 2009 | 09:19 AM
mrddk92's Avatar
Anybody ever use an e-fan on a 3vz and bypass the fan bracket pullys and all that? If I can't then I would have to replace the bracket and thos are kinda pricy compared to a taurus fan
Old Jul 24, 2009 | 01:04 AM
Brainlessmoth's Avatar
Originally Posted by iamsuperbleeder
you could always go...
at least that's the setup geting dropped in during my 22re rebuild
what kind of relay did you use? i just attached the positive end to an ignition curcut, and the neg to ground.
ALSO: built a new shroud (caus the ole on got ripped apart by the old fan ) out of stove pipe and a good coating of paint. i figured that the palcement wouldnt draw as much air through the radiator)
Old Jul 24, 2009 | 09:22 AM
Kiely's Avatar
Originally Posted by kiyobrown
Has anyone tried one of these? I have only found people doing the electrical fan swaps. Doesn't seem like it would make a huge difference, but there is one on craigslist locally, so at least I wouldn't be paying retail to find out. Any feedback would be appreciated. And yes, I used the search function.
Have a good one.
http://www.toyotacatalog.net/M1WebGe...4-36F6A5C0BDC2
To me, that is a fan more suited to a high speed off road racing application. If that's what you're doing great, if not save your $$$.
Old Jul 24, 2009 | 12:57 PM
  #25
iamsuperbleeder's Avatar
wired in a complete separate control unit with it's own relay that turns the fan on and off depending on tempurature, AC on, or my over-ride on. the relay powers up the + wire for the fan, while the other wire is grounded to one of the radiator mounting bolts
Old Jul 24, 2009 | 01:00 PM
  #26
93YotaGuy's Avatar
I have a black magic flex-a-lite fan on mine.... I love it!
It cools the coolant perfectly and have it set to where it comes on after a certain amount of heat.
Also, It added some power. I think that flex-a-lite says you gain anywhere from 10-15 horses just by putting it in
Old Jul 24, 2009 | 01:42 PM
  #27
technically, it doesn't really add any power per say, it just free's it up, lol
Old Jul 24, 2009 | 03:21 PM
  #28
93YotaGuy's Avatar
So freeing up the power that the motor once had would technically be adding the power back right?
Old Jul 24, 2009 | 03:24 PM
  #29
taking weight off a drag car doesn't give it more power, just makes the available power more usable
same concept when removing a mechanical fan; you're not making the motor produce more power, you're just making it to where the motor can put that power it was using to turn the fan, now to the wheels
this is like that Mythbusters episode, trying to take off in an airplane while on a moving runway, lol
Old Jul 24, 2009 | 03:34 PM
  #30
93YotaGuy's Avatar
I am ADDING my available power back by using a flex-a-lite electric fan. :-P
Old Jul 24, 2009 | 03:38 PM
  #31
lol, okay I give up
Old Jul 24, 2009 | 03:44 PM
  #32
Hayes's Avatar
Originally Posted by turborich
I would rather have the stock clutch fan any day over that little electric fan. The fan clutch doesn't rob you of more than a few HP. The factory clutch fan is a great fan & works very well. If you are overheating from slow crawling then by all means get a good OEM E fan. If you don't run hot then I wouldn't change a thing cause you won't gain enough power to feel.
Just my experience.
True, I can't feel the power but it runs a hell of a lot smoother.
my factory aisin fan keeps my motor at 180 when wheeling I jump to 210 I would not change it. Another thing to consider is water crossings I dont think the LCE fan would like slapping water, oh yea and yourengine bay might get pissed off too.
Somehow I think this fan was designed for the race crowd, not the wheeling crowd.
tiz the reason for the 3 position switch
Down is fully auto with temp and AC, middle is override off, and up is override constant on
that's how it's supposed to be. Mine is wired straight to a switch that I turn on before I turn on the truck.
smthwsn357
May 1, 2024 07:28 AM
Colington
Mar 8, 2020 09:51 AM
coryc85
Sep 9, 2015 06:24 AM
Jonny246
Jul 12, 2015 04:51 AM
zd92655
Jul 5, 2015 04:25 PM
