The Knock Sensor from Hell
Old Nov 4, 2014 | 03:36 PM
Gevo's Avatar
I believe Scope mentioned in this thread before... but here it is again fyi zombie. When the ecu doesnt get a good signal from the knock sensor, it shows the check engine light and retards the timing. The resulting power loss and fuel guzzling is ridiculous. This is to save the engine from potential damage.
Old Nov 4, 2014 | 03:37 PM
PyroJim's Avatar
Yep, we have done the external knock sensor several times with several sensors. I did it yesterday, using the 1990 sensors (2 different ones) and both still returned the 52 code.
Old Nov 4, 2014 | 05:09 PM
zombie_stomp's Avatar
Sorry for making this part for my education, but every time this code is detected, it makes the ignition retard and guzzle gas? Is that what's been going on besides not passing inspection due to a check engine light? I'm sorry if it's been painful to suggest before that this vehicle just needs to be parted out or something, unless that different year ECU changes the state of things, or unless the engine in the other truck is satisfactory.
Old Nov 6, 2014 | 08:48 PM
Punchy's Avatar
The knock sensor only picks up a specific frequency which is equal to a ping.
The ECU detects a impedance reading to know its there.
The only thing the ECU (OBD1) will do is retard timing or go limp mode when not detected at all, Other then that, Nothing.
Old Nov 7, 2014 | 06:58 AM
  #25
scope103's Avatar
Originally Posted by Punchy
...The ECU detects a impedance reading to know its there....
I don't think that's how it works. First, the explanation of code 52 is "With engine speed between 1,600 rpm – 5,200 rpm, signal from knock sensor is not input to ECM for 6 revolution. (KNK)."
Second, the knock sensor is a piezo sensor, which should have infinite impedance at rest.
Third, if the ECU detected the sensor by impedance alone, you know that someone would have "bypassed" his knock sensor with a resistor.
I'm pretty sure the ECU is listening for the signal from the sensor, and when that's gone (for 6 revolutions), it throws the code. I don't think impedance has anything to do with it.
Old Jan 4, 2015 | 10:00 AM
  #26
broncotoyo's Avatar
the end of mine broke but hasn,t thrown check engine light, pushed the end back together and epoxied it hope it works. not sure what it is for but will look for another one at wrecking yard. over 200.00 is ridiculus for a new one, excuse the spelling
Old Jan 6, 2015 | 08:23 AM
  #27
shaeff's Avatar
Right as usual!
The link in my signature below has pictures I uploaded of the Toyota manual regarding the Knock Circuit.
Old Jan 6, 2015 | 08:41 AM
  #28
bswarm's Avatar
This may or may not help. I had a ford come in with a knock sensor code from hell, finally narrowed it down to a rattling bracket near the sensor tripping the code.
Old Jan 16, 2015 | 04:34 AM
  #29
shaeff's Avatar
Certainly not on Toyotas. Code 52 is a problem with the knock CIRCUIT. It does NOT mean that the sensor/ECU are detecting knock.
When the Knock Circuit functions properly, it's 100% invisible to the end user. When it does not function properly, code 52 is set.
The problem exists somewhere between:
ECU (not common)
Sensor (reasonably common at this age, replace with OEM, not parts store junk!)
Wiring (most common)
Old Jan 16, 2015 | 06:29 AM
  #30
bswarm's Avatar
Like I said, it may or may not help. The problem Ford was sending too many "knock detected" signals tripping the code and check engine lamp.
Old Jan 16, 2015 | 08:39 AM
  #31
scope103's Avatar
I would be really surprised if Fords work this way, but we know Toyotas do not. A rattling bracket wouldn't produce the right frequency to do anything. But even if it did, "too many" knock detected signals would only retard timing, not throw a code.
As Schaeff says, code 52 appears when there is NO signal from the knock sensor.
Old Jan 16, 2015 | 10:32 AM
  #32
grumpin's Avatar
My peabrain tells me if the piezo device from Radio Shack gets rid of the cel, everything to the sensor is good. After reading this I can't remember, did you use a factory knock sensor? If not I would.
Old Jan 16, 2015 | 12:55 PM
  #33
bswarm's Avatar
This was an early 80's Ford, and yes it does kick a code and CEL on too many knocks detected. On later models with OBDII you could tap on the block and watch on a scanner the knock sensor detecting a ping. Anyway, the cracked/rattling bracket was fixed, and the code never popped up again.
Old Jun 24, 2018 | 03:28 PM
  #34
Red4x4's Avatar
Code 52
Originally Posted by PyroJim
Ok, here's the latest on the Knock Sensor from Hell:
1) We double checked ground connections. We added additional grounding/bonding straps just for fun. This sucker is grounded. This made no difference whatsoever.
2)Researched the grounding at the knock sensor issue. Gevo and Scope you were correct. It as absolutely NOT grounded at the sensor. The pig tail is two pole and reduces to one pole right before the sensor connects to a one pole plug. The shield is just flying and taped/heat shrunk at the factory. I stand corrected.
3) Tried mounting the knock sensor outside of the engine again. Same result. Check Engine. Code 52.
4) My son did some more Googling and found a guy somewhere with a similar problem with a knock sensor on a Honda. The Honda guy solved it by buying a piezo transducer at Radio Shack (part #273-0073) and installing it in place of the knock sensor. I'll be damned if it didn't work! No more "check engine" light, no more code 52.
I understand that we currently do not have any anti-knock protection, but on the flip side, we also do not have a check-engine light and we can get the stupid thing smogged.
It only took two years. Technically, we still have not solved the problem, but we have treated the symptom and for the time being we're calling it a victory. I'm hoping that the check engine light stays off long enough to just get past the smog test.
What a PIA.
hi do you recall how he hooked up that part tried it but didn't work any help
djohnson13
Sep 4, 2015 12:35 PM
shrek99352
Aug 31, 2015 04:16 AM
raptor510
Aug 19, 2015 02:15 PM
Flossy
Aug 5, 2015 05:14 PM
