Knock Sensor
Old Jul 23, 2009 | 08:10 AM
TFJ-4runner's Avatar
Knock Sensor
Can anybody tell me the resistance on a good knock sensor. I have a check engine light due to the knock sensor. The harness wiring is throwing out ECU's because of it. Mine only reads the negative signal.
Thanks
Vehicle Specs:
94 4runner
AT/ 4X4
3VZE
Old Jul 23, 2009 | 08:50 AM
dieselloco427's Avatar
According to my Chiltons manual - there should be no continuity. I can't seem to find anything in the FSM about the knock sensor.
Old Jul 23, 2009 | 12:07 PM
Up...
Old Jul 23, 2009 | 12:20 PM
iamsuperbleeder's Avatar
Yeah I would think that a knock sensor would be basically an "on/off" switch
it's either nocking, or it's not, lol
the typical and easy way to test is to start the motor, put a timing light on it, and while watching the timing close, lighty tap on the engine block with a hammer. the sensor should pic it up as a knock and retard the timing a little for a sec
at least that'll tell you if it's working if it DOES retard the timing, but if it doesn't, then the search begins could be the sensor itself, ot ir could be wiring...
Old Jul 24, 2009 | 05:03 AM
TNRabbit's Avatar
It's almost ALWAYS the pigtail wire that runs to the knock sensor. It runs under the intake manifold, so you'll have to remove the entire plenum & manifold.
jb451
7
Oct 7, 2022 06:58 AM
1uzRunner
63
Nov 10, 2018 03:58 PM
Kreedy1
Sep 8, 2015 06:33 PM
moparbay
Sep 3, 2015 12:48 PM
northwalker
Sep 3, 2015 12:21 PM
