Just stopped running - think it's fuel related
Old Apr 8, 2009 | 03:24 PM
89whitetoyota's Avatar
From: Cincinnati, Ohio - Amelia is the exact place. There is no one else on this site from where I am. Seems like everyone is from Cali or Washington. I guess I need to move.
Originally Posted by av3fire
i talked to a friend who had a 89 yota PU..... he told me the same thing.
took off the right front wheel and there it was (i am already missing the fender well skirts due to body lift and wheelin') the bolts were on pretty good, but a little power blaster and flare nut wrenches and i got it off and the new one on.
Still doesnt start, so i will get the fuel pump tomorrow and try that this weekend.
yipee!?!?!
t
Broski, can you hear the pump kick on when you turn the key to acc? You can hear it buzzin if you go to the back and listen. Does is come on or not? Take the line off the rail behind the throttle body and see if fuel is coming out steadly.
Old Apr 8, 2009 | 03:25 PM
also check your grounds and make sure they are all good, you dont want to do all this ish for a loose ground either.
Old Apr 8, 2009 | 03:54 PM
934rnr's Avatar
Sounds all too familiar change your fuel filter.
Old Apr 8, 2009 | 04:12 PM
I thought he said he did?
Old Apr 9, 2009 | 01:50 PM
  #25
av3fire's Avatar
had a friend turn the key.... quite as a church mouse......
off to get a fuel pump then i may attempt to install tonight, may wait til tomorrow.
thanx
Old Apr 9, 2009 | 03:12 PM
  #26
thanx
There ya go, i just home your sending unit lines up top aint ished out or you will be going to the stealership with 150 bones in your giving hand. I went to change my pump and those things were so rusted the bolts snapped off trying to get it off the top of the tank. Anywho...now you know what it is, fix it and let us know how it goes.
Old Apr 9, 2009 | 04:24 PM
  #27
av3fire's Avatar
my little $950 toy is getting expensive..... just spent $165 on a fuel pump and screen that was required for the warrenty........
not trying tonight, sposed to rain tomorrow, so i alredy pushed it under cover so i can have something to do if it does rain!!!!
t
Old Apr 9, 2009 | 04:40 PM
  #28
sb5walker's Avatar
Just turning the key to acc won't power the pump - the circuit opening relay works off the start signal or the fuel pump switch in the air meter. Jump B+ and FP in the check connector, then turn ignition on, and THEN listen at the pump. Also, without a jumper, check that FP is hot when a helper is turning the motor over.
Coils, when they go bad, act very much like fuel pumps do when they go bad. But if you've checked spark, then, probably the pump.
Old Apr 10, 2009 | 03:44 PM
  #29
av3fire's Avatar
here is an update.......
dropped the tank and found the power wire had coroded at the tank connection.
pealed off the exopy coating, resodered it and then recovered it in epoxy.
mine is not as neat as the factory, but i am only interested in getting a couple of years, not the 20 it lasted the first time.
get to return the $165 fuel pump, as i never installed it.
was not really that bad to drop the tank, only 6 bolts and the filler lines once it was empty.
THANX to all who made suggestions!
t
Old Apr 10, 2009 | 05:43 PM
  #30
good point, I have mine jumped, so i see where your coming from. That was misleading on my end. I apologize.
Old Apr 29, 2009 | 07:32 AM
  #31
drbarnes's Avatar
My problem is similar but is very sporadic, it will work fine for a week or two and then not start, when i try it again in a few days its hit or miss if it will work.
My question is will a fuel pump die slowly or will it just not work anymore?
icentropy
Jul 11, 2015 07:21 AM
Jnkml
Jul 6, 2015 01:20 PM
wilbertd
Jul 6, 2015 07:39 AM
karbin
Jul 5, 2015 11:37 PM
zd92655
Jul 5, 2015 04:25 PM
