Just installed rebuilt valve cover
Old Nov 27, 2009 | 10:39 PM
jimep's Avatar
valvecover filter breather, chrome dipsitck, and 710 cap, another 20hp combined
Old Nov 28, 2009 | 08:38 AM
CHEEZBURGER's Avatar
I completely forgot about the foot print gas pedal cover, that usually adds about 3 ponies
Old Nov 28, 2009 | 08:44 AM
Junkers88's Avatar
Originally Posted by abecedarian
I was holding back on reporting this, but I'm prototyping a valve cover that turns the stock valve train in to a desmodromic configuration with roller followers over the cam and hydraulic tensioners.
Basically, the rocker arms follow the cam with rollers and there are hydraulic adjusters taking up the slack. What's not seen is the linkage that is part of the valve cover and uses hydraulic principles and closes the valves without the high tension from the valve springs- just a little bit to keep a valve closed.
It's like what you'd expect if a 'yota cross bred with a Ducati motorcycle.
My hold-up is "prior art" and feasibility studies.
What?
Old Nov 28, 2009 | 08:50 AM
Teuf's Avatar
Junker how are the Tread Wright's holding up, (COUGHofftopicCOUGH), I am due a set of tires and was considering them.
Old Nov 28, 2009 | 08:51 AM
  #25
Junkers88's Avatar
Still have tread on them so no complaints so far. No flats ever and the tread hasn't started chunking off. All in all I'm damn happy with them and will be buying another set if I decide to stay with 31's.
Old Nov 28, 2009 | 08:54 AM
  #26
92 TOY's Avatar
I'm not as skilled as yous guyz....so I sent my valve cover to a machine shop....said they could machine it / bore it out / dip it / spin it / demagnetize it / hone it / and put it in bubble wrap for just under $500.... a bargain .....if only I didn't throw away the sandpaper instructions I could probably do the job myself.......but then again, I don't have a spray booth.
smthwsn357
May 1, 2024 07:28 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
jasonty
41
Dec 23, 2018 01:00 PM
Sep 4, 2015 09:27 AM
87blyota
Jul 10, 2015 04:31 AM
