Just did a Zuk Mod...
Old May 11, 2011 | 06:11 AM
  #321
Mojave_Moze's Avatar
Wow, this thread exploded since I saw it last, lol. I've had all the required parts do this mod for quite a while now, all except one: My fabricator buddie's precious time! lol. So should hopefulyl be doing the mod this Weekend. Pics will be posted on my build thread. Will probably be doing a complete custom weld-on mounting system, my fab buddy knows what hes doin so it should turn out pretty good!
Old May 11, 2011 | 08:20 AM
  #322
chubbydude's Avatar
If you make a top mount, the frame can be ground smooth and the upper mount bolted to the frame with 2 bolts with the frame tapped for them. This makes install of the coils a lot easier as you can put the mount in the coil and compress slightly and slide it into location. As with any thing there are good, better, best ways for doing things.
Old May 17, 2011 | 09:20 AM
  #323
edeslaur's Avatar
This dude loves his. Check out the load on his truck!
Ok appx 2 weeks until go time. New shocks ordered, locked, regeared 3rds ordered, all the stuff for my front lift ordered.
Link to the buildup thread: BlaZuk!
Old May 17, 2011 | 11:58 AM
  #324
ChefYota4x4's Avatar
You'd better share it here, as well, homie! lol... Zuk might come'n'getcha! lol.
Glad to hear, ...hope he does a REALLY nice job!
Old Jun 4, 2011 | 05:47 AM
  #325
erichill17's Avatar
im looking to take my 89 runner and turn it into a rock crawler. this will be my first conversion i have done so looking for some advice. it has a blown motor 3.0 so want to swap it for what would be best for this. everything on it is stock so im planning on redoing it all. dont want to waste money on brand names or over priced parts but still want a great product. any suggestions?
Old Jun 4, 2011 | 08:47 AM
  #326
Teuf's Avatar
Welcome. Its clear you have a plan. I would search your plan out AND take advice from others. Searching would be faster as someone with good advice may be on vacation or something like that. PS swap in a 22re.
Good luck
Old Jun 10, 2011 | 05:41 PM
  #327
KatKrazy's Avatar
I just did this mod with Tj springs. See the pics on my build thread:
https://www.yotatech.com/forums/f199...-build-236250/
Old Jun 14, 2011 | 11:03 AM
  #328
87 'runner boosted's Avatar
Has anybody on here done the ZUK mod and then cut the back half of the leafs off, kind of a cheap "link" set-up?? Didnt know if it would work, but couldnt figure why it wouldnt????
Old Jun 14, 2011 | 11:29 AM
  #329
ZUK's Avatar
ZUK
Ha! Ya, I thought about it....the only way it could work is to have a trackbar(panhard rod) and the front of the thick overload leaf would have to form fit to the normal arch of the pack and be close-clamped. The coils would need to be secured on both ends. It would certainly be different. No one has ever done this exact thing since recorded time.
I already have the overload close-clamped.....so all I would need to do is fab a track bar and chop the back half off.....and upgrade my particular 100lb/inch coils to 150 or 175's.
https://www.yotatech.com/forums/f116...f-leaf-225251/
Old Jun 14, 2011 | 11:50 AM
  #330
what consists of building this track bar and whats it purpose??? i tried googling so i could start wrapping my mind around what/how it could work and how to build one. you dont happen to know of any pics or anything out there do you?
Old Jun 14, 2011 | 12:18 PM
  #331
xxxtreme22r's Avatar
trackbar aka panhard keeps the rear end centered (left to right) under the truck. Well tries to anyway.
Old Jun 14, 2011 | 01:41 PM
  #332
alright, so here is my theory : if you have install track bars...why have the leaf springs at all?? its basically like have a solid tie rod with adjustments at one end attached to frame and diff right??
Old Jun 14, 2011 | 01:57 PM
  #333
trackbar aka panhard is different then control arm aka trailing arm. With the example on hand you would be using the leafs as the trailing/control arm and would just have to fab a panhard.
I don't see it working very well since the leafs aren't exactly ridged even with the overload close clamped, but I could be wrong.
Now what would be interesting is using 2 bud built traction bars and getting rid of the leafs altogether. Almost making it like a 3 link.
Old Aug 1, 2011 | 09:55 PM
  #334
Ok, ....so, just for a point of reference for those wondering..... I have 12"x125# coils in the rear, inserted into the upper stops with only the very edge cut off... In the pics, I have 600# in the VERY REAR of Ole Ruby Red...... and it maybeeeeee dropped .5-.75"!
I will be in Lake Havasu, AZ, as I said, ...and this time, I'm going to really try to find a few minutes to get down to the dunes/rocks and get some test pics of some flex... not sure I can, as Pops needs as much time with me and the daughter as possible... but HE DOES SLEEP, AND I HAVE LIGHTS, YA KNOW? hahaha.
Cya L8r, Yotatechies!
Old Aug 2, 2011 | 03:38 AM
  #335
Utah4Runner86's Avatar
Looks good, Chef! I did the exact same thing with 14in 125lb coils, and I've got a slight rake even with 1.5in spacers on the front joints.
I may switch over to add-a-lead or OME down the road to see if I can level it out, but right now it's got the rear off the bumpstops, and that's what counts!
Old Aug 2, 2011 | 07:45 AM
  #336
ZUK's Avatar
ZUK
[QUOTE=Utah4Runner86;51763501................. 14in 125lb coils, and I've got a slight rake .................................................. .................................................. ...........................................but right now it's got the rear off the bumpstops, and that's what counts![/QUOTE]
well said
ZUK
ps--If you do swap the coil out for an AAL or new pack, I wonder if you will notice a difference in the way your rig handles bumps and loads.....so much so that you might choose to put the coils back in ? Just thinking out loud
Old Aug 2, 2011 | 08:01 AM
  #337
Thanks, Phil, and great to hear, man!
Zuk, .... I will ONLY do the leaf pack method when I can do it VERY solid. (OME or Tundra or whatever the kids find is most comfy and flexy and, well, permanent! lol) These things(the 12"x125# coils) have paid for themselves in practicality 3 TIMES OVER! The ride, the weight capacity and, well, that leads me to something else.....
I see many arguing that they LOSE flex compared to the AAL..... But then some saying "They lost almost all their flex with the AAL, maybe I should try this"....... And I suppose it would make a difference how they're mounted, is the right spring length in, right shock length, etc., depending on the amount of lift from them, etc., etc. lol. I plan to at least TRY this week in Havasu to dual/opposing flex test this out. One thing I notice is that, ....with weight in there, even a couple hundred pounds, ...the ride is DEFINITELY nicer. .... but then again, I'm running longer RS5000's..... YEAH, I know, lol. Keeping my eyes open for a set of used or SUPER SALE Procomps or something a lil softer in general....then I'll get an idea.
Anyway, hope you're well, Zuk! How was the vacation(you took an extended one, right?.... or was that Wabbit? hahaha) EEk, sorry, .... just can't remember, lol.
Old Aug 2, 2011 | 02:54 PM
  #338
Junkers88's Avatar
Don't mean to thread jack here but Zuk I was wondering if you could answer this for me. I'm considering (next spring) doing the SAS on my 89 (currently has the Zuk on it) and going with a 3" lift when I do. I'd like to keep the Zuk mod in there with longer coils to help with load capacity, man I carry a LOT of stuff when I go camping and out in the hills.
Thoughts on a coil length? I have the 14" 125lb ones in there now and would probably need something like a 17" coil once the lift is done.
Or is this a bad idea?
Old Aug 2, 2011 | 08:51 PM
  #339
ZUK's Avatar
ZUK
Not sure exactly what you mean....if you sas it then I guess that means the front will look too high....so you have to add more lift to the rear?
...which is entirely possible to do also. I don't know about 17 inch coils.....I know how nice the 14 x 125 ones seem to ride but I'm not sure about the 17 inch fatter ones out there.
Longer shackles and a spacer to space the coil (your 14" one)out more. Of course, at this point I would recommend spinning the overload 180 degrees and have it professionally bent upwards so you can hard clamp it like I did for my Taco but in your case do not cut the rear half of the springboard off to keep the max load carrying capacity.
Old Aug 2, 2011 | 10:45 PM
  #340
Dunno yet. If I decide to go that route, I'll let you know if I notice a difference.
