Just about had it (sputtering issue)
Old Oct 27, 2008 | 07:14 AM
rdlsz24's Avatar
Glad to hear you figured your problem out. Wouldn't you know I drove mine the other day and I was getting a stumble in every gear around 2000 rpm. It wasn't doing it the other day so I knew something came loose, etc under the hood. While looking around I noticed one of the wires going to the green plug under the intake manifold (this is a coolant sensor for the ECU) was broken. Once I fixed that wire it ran fine again. Something to look at for anybody else that stumbles across this thread.
Rob
Old Oct 27, 2008 | 09:29 AM
ZUK's Avatar
ZUK
Originally Posted by MHST Guy
Funny story about that. So the day after I replaced the fuel pump, I was taking a longer test drive. It was still sputtering. CEL came on. Knock sensor code was the only code stored. Unplugged the knock sensor, but it was still running the same way.
.......................I had a bad wire, recieved a second set with a bad wire. What are the odds?............................
Ha! I put 4 years in at Autobone and I would never let my worst enemy have a set of after-market wires like yours you should think about getting a Genuine Toyota wire set. There is no comparison.
Old Oct 28, 2008 | 07:48 AM
MHST Guy's Avatar
I run the top of the line wires in all of my vehicles (including my turbo Typhoon and my turbo Omni), and this is the first problem I've ever had with them. Lifetime warranty means I can change them out once a year if I feel like it
Old Oct 29, 2008 | 06:37 PM
muddpigg's Avatar
I wound up having the same problem, ran like crap at lower RPM's but better at higher range, I got home after dark. So went to look under hood w/ flashlight. #4 was arching from top of boot to head. Finally cut those custom wire set to length.
Old Oct 29, 2008 | 06:42 PM
  #25
waskillywabbit's Avatar
So all this was fixed by replacing bad plug wires? OEM on plug wires...always.
Old Oct 30, 2008 | 12:28 PM
  #26
ozziesironmanoffroad's Avatar
mines doing the same thing now, except its not throwing any codes.. boy oh boy do i have some fun ahead of me....
Old Oct 30, 2008 | 02:03 PM
  #27
mnmontana's Avatar
I had a similiar issue, but it was fuel injector connectors.
Old Oct 30, 2008 | 02:15 PM
  #28
already fixed them, should i check em again?
Old Nov 1, 2008 | 06:50 AM
  #29
MHST Guy's Avatar
How long since your last tune up?
Charecter1
Nov 6, 2023 10:08 AM
nvdesertrunner
May 11, 2020 08:18 PM
crammit442
7
Nov 29, 2017 12:30 PM
Sidherish
Aug 2, 2015 01:42 PM
montanatruck
Jul 25, 2015 03:45 AM
