ITS alive! 3.0 afm mod!
#121
Negative
What I am saying is that the rpm's clime faster and stay in the higher range longer causing the speed to clime more steady and maintain the same speed sooner then before.
Basically it's like adding another cold air intake and cleaning the injectors at the same time with the way the rpm's clime and the power comes on longer then before the AFM swap but I still need to dial it in I am not getting anywhere close to 90 miles at a 1/4 tank in fact I just tuned 100 miles at 1/2 a tank not much different then pre AFM swap
OK, I see. I was frustrated by the slight lug when shifting as I drove in this morning. If this can provide better performance with no MPG penalty then I'll probably still give it a try. I just need to find some time to get over to Pullapart.
Thanks for trying this out and reporting your results.
#122
my 90 miles per 1/4 tank is for a couple reasons
1 im under geared and dont drive my motor hard
2 i ALWAYS keep it under 2700 rpms nomatter what
green 93 it will fit your old lid without drilling just sticks up abit i have a piece of gasket material filling in that void on top as
if anyone kows an easy way to tell if im lean or rich ( besides pulling plugs) let me know how i wanna show the results from that to everyone
#123
#124
ok kids heres what im seeing so far!
gas milage......... is about the same im still getting around 300+/- a few for tire/ gear size and city highway but always more then 250 everyday and just under 400 all highway.
performance......... i am seeing more torque in the middle. its hard to say if its all the way through the band.maybe the sound be it feels more responsive pretty much all the way thhrough the band.
lower end pulls hard middle is still pulling and highway driving can keep speed better and increase speed up hills without the trans downshifting.
overall............ as the weeks progress ill keep updating, however, uptill now i think that for 17.22 for the afm ill keep it on ! im not losing performance and have gained in places. my thoughts are this: the motor can breathe all it wants now. however, i feel that it cant do anything with that air. larger intakes or boring may be able to use the increase in airflow.
im telling you what their is a ton of air going in now! and if we can find a way to use it i think this is the start to a great 3.0 mod
anyone that has bored camed or reworked the intake may have huge gains from this. ill keep messing with it or a while longer and kepp everyone posted
#125
#127
well duartizzle what is your truck set up like????? tire size cat muffler gears?? and did you read the part where i stated that i stay under 2500rpms at all costs! That alone kicked me up from 70 a quater to 90 that and i run alot of highways. like i said before im around 300 city/highway combined and closer to 400 all highway (drafting semis included) that also factors in my speedo is off cause im running 285s
#128
almost forgot duartizzle my timing is set at 15 insted of 10 like factory
if im not mistaken from the factory this got 16 and 20 auto and 18 /22 stick
#129
#131
I don't have anything else to say on this topic, even after reseting my ecu I am still getting the same mpg as before.
#132
does anyone know if this mod is making your truck run too lean though? And how do you get to the article on 4crawler? I picked up an afm the other day at a junkyard to see if it really did anything.. i figured it was worth $16 to see for myself, but i dont know what wheel you guys are talking about that youre turning counterclockwise?
#133
#134
#135
Finally got mine installed. I modified the OEM air box cover to fit the new AFM from a '90 Camry V6 which was plug n play
So far from what I noticed is the throttle response is way better than before, 1st gear start from a stop is really smooth. As far as gas mileage we'll have to wait n see.
If this makes no difference with gas mileage, oh well...it drives real nice.
#137
If I'm feeling ambitious and if I can get my hands on a used MAF, I'm going to try replacing the VAFM with a MAF. After doing a little homework, it looks like it would be relatively easy to do. The big question is whether it would be worth it or not.
#138
what this mod does is replace one VAFC for another that has a slightly larger intake hole - much easier to do as it's mostly plug and play
#139
Could you take some pictures of the modifications you had to do to make everything fit properly? I aim to do this mod without the use of tape
#140
to replace your VAFM (Vane AirFlow Meter, with a flapper door) with a MAF (Mass AirFlow, with a heated wire element to detect airflow) you'd need a signal converter, and then you'd need to tune it, the two types don't work the same at all - not relatively easy to do, and not cheap
