I have one, but Ca. If you know anyone traveling lmk. The latches i sold on eBay.
No luck at the PYP yards in NC? When i bought my 4R the tailgate had a pretty large dent and was bowed. I went to a PYP and got a whole tailgate with everything inside(glass, hinges, latches, motor, weather-stripping, etc) for $50.00
Ive looked at all the local ones and 4runners are non existent here. I wish i could come across a whole tail gate for 50.00 lol i’d give em 100
The glass and the latches the last thing left on the ole 4runner
I have latches, hinges, spring thingy at the bottom and the wiring harness. Plugs in at the drivers side corner of the tailgate, still has a good grommet and i have the little cover for where it goes into the bottom of the tailgate.
also the rubber seal that goes around the bottom and sides of the tailgate and the little cover
FYI you can still get the outside sweep for the back window and the clips for the inside from toyota oem.
the sweep was like $60 the clips came on it... the inside one is discontinued but, you can get the clips and they're cheap.
I also have a good glass but the channel it sits in was bad... so it's just the glass.
