IP Gauges Fail, Signals Fail, Battery not charging
Old Jun 3, 2007 | 04:20 PM
jungle_runner's Avatar
Question IP Gauges Fail, Signals Fail, Battery not charging
88 4runner. Replaced my alternator two months ago after the battery wasn't charging, Parking Break & Charge lights were on, and truck finally stalled.
Truck was running fine until two days ago the Charge light came on and the fuel gauge, temp gauge, and turn signals all failed. Truck drove fine and didn't stall, but the battery fully discharged and the truck will not start now.
I checked the fuses and they all seem fine. Took out the alternator and had it tested and kragen tells me it's perfectly fine and that I can't exchange it because the warrenty says that it has to fail their test.
I did not find anything in a search. Any one have any clues?
Thanks
Old Jun 5, 2007 | 10:52 AM
Smile The answer was simple...
GOT IT!!!
I was doing research on fusible links and came accross a site that dicusses the locations of fuse boxes in a 4runner. I thought there was just one, the one under the hood next to the battery. But there are two more, one behind the driver's side kick panel and one behind the glovebox.
I had a blown fuse in the fuse box on the driver's side. Replaced it and now all the instrument panel gauges are working and the alternator is charging.
Thanks
Old Jun 5, 2007 | 10:00 PM
notanymore's Avatar
good that you got it figured out
80Truck
Oct 12, 2025 07:25 PM
moonpie
Jul 31, 2015 11:58 PM
mr_manny
Jul 31, 2015 10:39 AM
Esibnitsud
Jul 30, 2015 08:19 PM
kvanzandt1
Jul 18, 2015 10:15 AM
