Internal Valve Cover Gasket (Baffle)
Old Feb 9, 2010 | 07:57 AM
Hilux808's Avatar
Has anyone changed the gasket inside the valve cover on a 22RE? It's the one for the baffle. I just got the master gasket set from engnbldr and a baffle gasket is included. The baffle appears to be riveted on. I tried searching the forum but haven't found anyone with a thread to say how they did theirs.
I normally wouldn't change this but the old gasket is falling apart and I don't want chunks floating in the oil.
Old Feb 9, 2010 | 09:00 AM
flyingbrass's Avatar
I asked about this a few days ago: https://www.yotatech.com/forums/f116...baffle-203378/
Another thread: https://www.yotatech.com/forums/f116...r-22re-164498/
If you do it, let us know how it goes.
Old Feb 9, 2010 | 10:03 AM
Hilux808's Avatar
yeah, ran across those but just wondered if anyone had did it with pictures. I'll probably do mine and take pictures to post soon.
Old Feb 12, 2010 | 09:32 AM
dfarr67's Avatar
I was looking at that as well, but decided it wasn't worth the effort. Try vise grips and twist them out, or chisel them loose.
Old Feb 14, 2010 | 05:42 AM
tim a.'s Avatar
I asked this question a long time ago and got no real answer.If you take it off,you will have to use screws to secure it,and that left me uneasy.I just blew mine out with air and solvent,worked ok for me.
Old Feb 14, 2010 | 08:23 AM
abecedarian's Avatar
About mid way down this page, on the left: http://www.22reperformance.com/22RE%...20Process.html are two pics of the underside of the valve cover.
Using screws to secure the baffle shouldn't be an issue- just use the appropriate loctite to secure them in the cover.
On the up-side, having the baffle properly sealed will reduce the amount of oil sucked into the intake.
Old Feb 14, 2010 | 09:34 AM
JamesD's Avatar
SO THAT IS WHAT THAT GASKET IS FOR! All these years I could not figure out where it went. I would not bother to change it since it will not make a difference. I usually clean my valve cover with kerosene when I change the gasket. When I'm done cleaning it, I run water over it to rinse it out and then I blow dry it to get the water out.
James
smthwsn357
May 1, 2024 07:28 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
Sep 4, 2015 09:27 AM
irritech
Jul 27, 2015 05:15 PM
scottyg486
Jul 19, 2015 05:34 PM
