Intermittent starting issues. Single click
Old Nov 29, 2015 | 06:13 PM
Phantez's Avatar
88 22re. Ive been battling this starting issue for a couple weeks. It started with intermittent no start, just a single click, but if i kept turning the key over and over, it would sometimes kick in the starter and fire up. After a few days of that, it would never start. I figured the starter was bad. I changed that out with a reman from oreilly's and it was perfect for about a week, then started having intermittent issues again. Same single click. This time i changed out the starter relay. I just installed a universal one and wired up with the plug from the original. Still intermittent until today, now it wont start anymore.
I'm not sure if I just got a bad starter, or if there is something else I need to look at. Is there anything else I can test or look at before going through the hassle of pulling that starter again?
Old Nov 29, 2015 | 06:47 PM
Terrys87's Avatar
I have yet to have a starter to fail. Usually just replace the plunger and contacts in one and good to go. This thread is quite similar to your issue https://www.yotatech.com/forums/f116...-issue-292284/ Clean the starter relay contacts, replace plunger and contacts in the starter and look into RADs starter fix. I dont care for part store parts and usually have issues with them. Plenty of threads on parts stores. It is not just Orielly but the other big names as well. Look for OEM parts online and usually you can find them.
Old Nov 29, 2015 | 08:17 PM
RAD4Runner's Avatar
First, you need to tell us exactly what and where clicks because we could not hear nor feel it from where we are.
Originally Posted by Phantez
...just a single click...
...the starter was bad. I changed that out with a reman from oreilly's
....i changed out the starter relay...
You replaced the starter and the relay that you thought were bad but you you still did not fix the wiring of the starter relay that we are absolutely sure is wrong, like I described in my post.
...Still intermittent until today, now it wont start anymore.
Yes!
Before you spend hours and possibly close to a hundred dollars fixing something you think is broken, spend half an hour and a few dollars fixing something that the electrically-savvy are already sure is broken.
Old Nov 30, 2015 | 07:26 AM
Phantez's Avatar
It's clicking at the starter relay.
Can you elaborate a bit on what you're demonstrating on in that picture? Why does this modification need to be done? I'd just like to have a better understanding of what this is doing before I start cutting into my harness.
Also, at the bottom of the image, it says to insulate that wire. By that you mean it's just going to be unused, so cover it up the chopped end?
Old Nov 30, 2015 | 12:35 PM
RAD4Runner's Avatar
Good.
You always have to be specific when describing a problem because people trying to help do not see, hear, smell nor feel the symptoms.
Good job. Always good to understand what you are doing, and not just guess like many mechanics do (who then charge us for their wrong guesses).
Wiring Flaw Explained Here
Correct. That is the wire that is taking power from THE WRONG POINT.
Old Dec 1, 2015 | 06:20 AM
Phantez's Avatar
This worked! Although I'm sure you already knew that. haha. I feel like I need to buy you a beer
Old Dec 1, 2015 | 08:43 AM
RAD4Runner's Avatar
LOL! Cool! I drink to that!
tj884Rdlx
12
Jun 18, 2016 04:19 PM
ET
Oct 22, 2015 01:37 AM
CajunFisherman
Oct 17, 2015 06:12 PM
Rickstwowheels
Oct 14, 2015 11:37 AM
AFewScrewsLoose
Oct 9, 2015 06:53 PM
