intermediate miss
Old Nov 8, 2020 | 11:51 AM
barrentine's Avatar
intermediate miss
89 yota pick-up with 22re engine. I can start it up and runs fine and drive several miles and runs fine but when I switch it off and then start it back up it has a miss.It doesnt do this everytime but when it does sometimes I can switch it off and start it back up and it will not have a miss. Today I put a new fuel filter on and drove a few miles and it started missing so when I got home I started pulling plug wires one at a time and when I pulled number 1 off the engine did not change as it did with the other 3. So i put a spark tester on and its getting fire to the plug.Oh I put new spark plugs in also. With it getting spark I guess now Im leaning to the number 1 injector.Any ideas what else I need to check before pulling the injector? thanks
Old Nov 8, 2020 | 12:03 PM
wallytoo's Avatar
before pulling the injectors, swap the injector connectors, ie, from #2 to #1 and #1 to #2. if the miss stays at #1, the injector is at least part of the problem. if the miss moves to #2, the wiring to that connector is an issue.
Cliff459
Jan 4, 2020 06:59 AM
YoterPower
Aug 19, 2012 02:48 PM
affmondo22
Sep 11, 2009 07:31 PM
ltgvolsrock1
Aug 5, 2009 03:53 PM
tc
Apr 17, 2008 09:01 PM
