Instruction on valve adjustment 22re
Old Jan 29, 2008 | 08:30 AM
89whitetoyota's Avatar
From: Cincinnati, Ohio - Amelia is the exact place. There is no one else on this site from where I am. Seems like everyone is from Cali or Washington. I guess I need to move.
I set them with it cold first, and .20 (intake) and .30 (exhaust), and wow, the level of noise completely left. It no longer sounds like a diesel, even though I really wish it was. I had bought a new head so some of the valves were really wacked out, and just with a prelim adjustment the motor idled perfect (where before it would have a slight miss), and power through the gears seemed more consistant and tight.
Then did it again after warming it up and presto, the truck is running better than ever.
Thanks for all of the help here guys, and 4Crawlers link on this made it super easy for a first time learner on valve adjusting.
Old Jan 29, 2008 | 06:17 PM
84sr5yoty's Avatar
I'm assuming you mean .02 and .03. Either way, say bye bye to your valves if you want to run those tolerances. You shouldn’t go any tighter than .006 on the intake and .010 on the exhaust.
Old Jan 30, 2008 | 07:21 AM
I was describing inches on the feeler aspects which translates into the standard 8(intanke) and 12(exhaust) in MM specs. The truck is set to FSM specifications.
Old Jan 30, 2008 | 07:59 AM
MMA_Alex's Avatar
you mean you were doing mm. its .008in intake .012in exhaust, which is .2mm, and .3mm
Old Jan 30, 2008 | 08:11 AM
  #25
right, I apologize for all of the confusion. MMA you're right. Just for clarification, if anyone clicks on the link 4crawler gave me a couple responses up, those are the exact specs I set it to.
I forgot a couple zeros in describing the gauge i used, that was my bad.
Old Feb 4, 2012 | 10:43 AM
  #26
jmitchell2008me's Avatar
how long does this take like the whole procedure and on a another does rtv black set up if it like freeze cold outside like maine in winter
Old Jun 25, 2024 | 03:51 PM
  #27
adrian831's Avatar
Heqt
Originally Posted by Matt16
My knowledge is purely theoretical, but if the valves have no way to dissipate heat (ie using the head as a heat sink) the how do they cool?
oil my friend
Old Jun 25, 2024 | 06:12 PM
  #28
osv's Avatar
osv
Originally Posted by adrian831
oil my friend
there is no oil in the combustion chamber, where all of the heat is at.
"On a solid valve, the majority of the cooling happens from transferring heat through the valve seat and only about a quarter of the cooling goes through the stem. In a sodium filled valve, approximately 40 percent of the cooling is through the stem so the valve can tolerate more heat." https://www.enginebuildermag.com/201...res-explained/
squeege
Oct 21, 2020 05:26 AM
Eg-r
Aug 10, 2011 06:04 PM
jfly13
Sep 13, 2008 05:44 PM
skinnadoor
Jul 23, 2007 06:07 AM
