Installing Old Man Emu rear springs!!
Old 05-28-2012, 06:24 PM
93Xtra-Cab's Avatar
IMHO adding washers is just a shoddy way of fixing it. No offense. It might seem like a good, cheap idea but it just looks bad. I do like b4wheelers idea of removing the pin and just making it shorter. If there isn't enough thread on it, like you think, just use a die and make more threads. If you don't have a tap and die set, borrow one from a friend, co-worker, whatever. If none of this is applicable, I'd say return the shackles all together and get the correct set. If you can't return them maybe because you exceeded the return period, then you could sell them to a friend or something. I would use washers or shims as a last resort.
For future reference, 4Crawler has an amazing website with a plethora of information on just about anything, including shackles. He even sells custom made ones. His shackle page: http://www.4crawler.com/4x4/ForSale/Shackles.shtml
Old 05-28-2012, 06:41 PM
Mr. Gold444's Avatar
None taken, haha. I've been to 4Crawler a bunch lately though. That's where I got the front bolts, the sleeves and I just ordered ball joints spacers and a LSPV bracket.
I would say returning the shackles is out because I ordered them a few months ago from SierraExpeditions when I was collecting all the parts.
Just to clarify, are you saying that the washers will affect longevity or looks? Or both, because it's essentially jury rigging it?
Old 05-28-2012, 07:08 PM
BLKNBLU's Avatar
I would not necessarily give up on this. I have the good fortune to know Wil, the owner of Sierra Expeditions personally. They pride themselves on customer service and making things right. I agree that you got the only part listed for your model truck (OMEGS3) and it does not fit properly. That should not be OK. I suspect SE will go to bat for you with ARB/OME to either get the right part or get your money back...especially if they (SE) had a hand in helping you pick out the right part number. Stay calm and straight forward and explain your situation. See what happens. Good luck.
EDIT: You did yourself a favor going to a reputable vendor.
Old 05-28-2012, 07:23 PM
I wouldn't necessarily say that SierraExpeditions helped me pick out the parts, but after looking around I decided to order all my OME stuff from them. I already shot an email to ARB, so I'll call SierraExpeditions tomorrow.
Thanks for the input.
Old 05-28-2012, 08:03 PM
  #25
Luvmeye22re's Avatar
I wouldn't be opposed to throwing washers in there myself. I can't see it hurting anything and it would be a lot easier than tearing it down and shipping them back while having more down time on the truck. I wouldn't drive it much the way it is now though, it would probably tear those bushings up pretty fast.
Old 05-29-2012, 04:52 AM
  #26
93Xtra-Cab's Avatar
The more I think of it, it probably wouldn't affect longevity or anything. It's just going to affect looks.
Either that, or don't drive it at all. As it sits now, there is 18mm of play in both mounting point of both shackles. I don't know how long the bushings are, but there could be a possibility of one slipping out. Also, there would be a lot of movement while driving down the road.
Old 05-29-2012, 02:50 PM
  #27
I would see if you can just pull the spacer pin , and replace it with a shorter one or leave it out all together
Old 05-29-2012, 07:15 PM
  #28
Well here's the temporary fix. It should work until I get new shackles and I must say I've had quite the revelation today.
I'm not entirely sure as to why I didn't catch this earlier, but the shackle I have right now is the OMEGS1 NOT the OMEGS3. I talked to ARB and it turns out that the GS3 is actually the correct shackle.
I could have sworn I purchased the GS3, but my invoice from SierraExpeditions says otherwise.
Man I feel dumb haha.
Old 05-29-2012, 08:41 PM
  #29
ToyoTech559's Avatar
idk. i dont see why you cant just run it like that
Old 05-30-2012, 01:05 PM
  #30
highonpottery's Avatar
looks good!
you should technically be ok running the shackles this way. what length of shackle are those anyways? shackle length will have a lot to do with how tall it's sitting, and you may find need to swap them later once the leafs have finally settled.
when I did my truck, I got the same surprising 4-5" lift just like you did, with stock shackle - it was definitely raked. took about a year to finally settle all the way - i also "helped" it settle faster with several loads of compost and rocks for my garden. currently, the back of my truck is right around 22.5" from the center of the axle to the bottom lip of the fender. not sure how that compares to a 2nd gen since mine's a 3rd gen.
btw, ubolt flip kit or just triangulated shock mounts will give you back your rear downtravel. i got around 4-6" more travel just by doing this over the stock setup.
Old 05-30-2012, 02:26 PM
  #31
Truckstarr's Avatar
I tend to agree that you should be fine running this way. You can barely even tell that there are washers in place. My main concern was the bushing getting shredded and your fix looks like it'll do the trick to keep them in place. Personally, I wouldn't worry about getting the "right" ones. Especially for the price.
Old 05-31-2012, 06:28 AM
  #32
Bigdady's Avatar
Keep the ones you installed, btw your truck looks good.
Old 05-31-2012, 10:09 PM
  #33
unless you can get them swapped for the right ones for free. even tho you made a mistake on the order???
Old 06-01-2012, 03:50 PM
  #34
The shackles are essentially the same length as stock. Maybe an 1/8" longer. I think I'm going to keep everything shock mount related the same for a while.
Thanks Bigdady!
I emailed SierraExpeditions and they said they can swap me out if I call, which would be really cool of them.
I also got my ball joints spacers the other day. They'll go on once I get the ball joints.
Old 07-17-2013, 12:11 PM
  #35
Lance o Lot's Avatar
Shackles
Folks: I'm looking to OME my '93, PU, as well. But the OMEGS3 shackles are listed for '79 thru '88. Will these really work with my '93?
Old 07-17-2013, 02:39 PM
  #36
^I believe the 79-88 shackles are narrower than the 89-95 rigs. if going with OME i think you need the OMEGS1 version. you don't technically have to get OME shackles, any manufacturer will work especially if you can find them cheaper...like Trail Gear, Marlin Crawler, Ruff Stuff, etc - they are all the same as long as they're for Toyota as we use metric size holes in the bushings.
the only reason the OP had issues with his shackles is due to the center spacing pin, which sets the width. most shackles don't have this inclusion.
Old 07-17-2013, 03:30 PM
  #37
ChefYota4x4's Avatar
My OME 87 4Runner leafs had to flip the forward strap bolt 180..... It was going to contact the fuel tank pinch flange....... Even with the bolt to the strap flipped it was still going to make some contact with the fuel tank... so if I hadn't of went forward with my SAS I would have likely have moved the tank over around a half an inch.
Old 07-18-2013, 04:30 AM
  #38
My Bad
Thanks, Gents:
My bad; I missed that it was an '86, so wrong generation . I called ARB and was told that they don't make a greaseable shackle for the '93. I was hoping to use all OME parts.
Old 07-18-2013, 06:11 AM
  #39
Then just go with another brand. They are all basically same product and equal in quality for the most part.
Old 09-05-2013, 11:38 AM
  #40
I found a manual that lists the GS7 shackle for the 93 Hilux. Other than the shackle set, the ARB parts for the Hilux and Pickup are identical. Aren't those trucks one-in-the-same?
06-01-2021 01:51 PM
jerusry
10-19-2015 05:28 PM
BeMiceElf
10-10-2015 09:40 PM
Nickdigg
07-07-2015 06:04 AM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: Installing Old Man Emu rear springs!!
