Installing add-a-leaf..help?
Yep, center pin is typically offset to the front, so the rear half is longer. Easy enough to check by putting the spring in the hanger and see if the center pin is about in the middle of the wheel well, or just look for the end of the spring with the military wrap (2nd leaf wrapped around the main leaf) and that end goes in the hanger.
punks_is_4x4
Aug 21, 2015 01:35 PM
Esibnitsud
Jul 30, 2015 08:19 PM
