infamous sunroof cover
Old 10-16-2007, 01:11 PM
quackenheimer's Avatar
Hello all,
I was wondering if anyone would have a picture of what the sunroof cover lock hole looks like. Apparantley the sunroof cover was an option and my truck i guess did not come with it. I purchased the sunroof cover not knowing this. To my dissappointment i noticed that i could not lock the sunroof cover in. I talked to the place where i bought the sunroof cover and he tried to describe what it looks like but not sure. I talked to the dealer and as usual they don't have a clue. so I'm hoping that someone out there has the sunroof cover and could maybe describe or has a picture of what this looks like. It is the piece that the pin on the cover slides into it. I hope this makes sense.
Old 10-16-2007, 01:19 PM
Jay351's Avatar
I didnt know we could get sunroof covers
Old 10-16-2007, 01:50 PM
Actually after a little research i discovered that this was an option and most trucks didn't come with it. I had an 85 that came with it and so i assumed that they all came with it. If you look on your sunroof towards the front of the truck you should see two little tabs that stick out. that is what the cover hangs on to.
Old 10-16-2007, 02:03 PM
TORTIS's Avatar
the 85 truck i just bought, but have not received yet, has a sunroof that leaks. not to jack the thread, but is this a common problem if you don't have the cover?
Old 10-16-2007, 02:08 PM
Jay351's Avatar
I dont see how the cover would effect the seal of the sunroof.
and yes I see the little clip things, I never thought it was for a cover though.
Post up pictures
Old 10-16-2007, 02:13 PM
jason191918's Avatar
hope these help
Attached Thumbnails infamous sunroof cover-4.jpg   infamous sunroof cover-5.jpg   infamous sunroof cover-7.jpg
Old 10-16-2007, 02:15 PM
the cover is not air/water tight. as far as i know the cover is not that important. i only use it in the winter, because water condenses on it and it drips on you head.
Old 10-16-2007, 02:16 PM
TORTIS's Avatar
nope. wouldn't stop a leak.
Old 10-16-2007, 02:30 PM
SKNKWRX's Avatar
I would assume it is a type of sunshade?
Old 10-16-2007, 04:21 PM
Jay351's Avatar
ohh!!
Im missing the bolt and washer that you have pictured
anybody know where to get replacment?
Old 10-17-2007, 08:18 AM
4Crawler's Avatar
Here is the one from my '85:
For sunroof leaks, be sure and check the two drain holes in the corners. They connect to drain tubes that run down the a-pillars. If clogged, water builds up and can leak around the seal.
Old 02-18-2012, 01:47 PM
coganhagen01's Avatar
Unhappy moonroof cover
Please me cause im looking for one to fit my 00 toy Tacoma. Do they make a replacement one.Toyota wants 500and for new one.
Old 02-18-2012, 02:19 PM
slacker's Avatar
for leaks .. also try cleaning the weatherstrips and seals .. rejuvenating the rubbers , will usually cure the leaking issues
Old 02-18-2012, 06:58 PM
Will Toyota car panel fit truck??? Anyone know
Old 02-18-2012, 07:33 PM
BMcEL's Avatar
Huh? .
Old 02-18-2012, 07:43 PM
Will the moonroof panel from a Toyota car fit on a Tacoma truck are the same size?
Old 02-19-2012, 02:34 PM
ksti's Avatar
Most Toyota passenger cars have sliding motorized units with cover inside head liner area. Pop-up units a completely different. If its factory installed no aftermarket cover will fit, unless maybe you modify it. If it was added on from selling dealer then you probably can find a replacement cover.
Old 02-19-2012, 02:56 PM
This is in a mr2 I think that rite and has same pop off cover and sit up as truck. Don't know if same size im trying to get him to reply about size. But no luck yet it looks just like one in 4crawlers pic of his
Old 02-20-2012, 08:16 PM
pholife's Avatar
MR2 MK1 sunroof covers does NOT fit Toyota trucks.
Old 06-16-2021, 02:20 PM
injunmick's Avatar
Sunroof Latch 90 Toyota Pickup
Anyone know where i can buy this latch new for 90 Toyota 4x4?? (grey)...thank you
Quick Reply: infamous sunroof cover
