Illegal Cb Antenna Install??
As an interesting side note, most competitions no longer allow the use of the 1/4 wave whips because they are so dangerous to bystanders. If you show up with one, you fail the tech inspection and they send you home. I understand that some private wheeling areas and clubs are moving that way as well.
There are better solutions in this day and age
I have 30 dollars into my antenna, total. 15 for the antenna, and 15 for the quick disconnect connector, so i can run without the antenna except when wheeling.
I have tuned my antenna with an SWR meter, and i get a good mile and a half of recieving if on completely flat ground. When wheeling, i have absolutely no trouble hearing the guy at the front of a 15 truck line up, if i am the caboose. There are better places to mount it, for sure, but this stays out of the trees, and works well for what i use it for.
FS[PacNorWest]: Parting 2000 4Runner Limited 4WD Marysville, WA
DeathCougar
Apr 1, 2018 11:29 PM
punks_is_4x4
Aug 21, 2015 01:35 PM
