IFS Flex Pics
Old Mar 21, 2007 | 12:46 PM
  #121
Bear80's Avatar
FYI, it was with stock t-bars. When the t-bar height is messed with the alignment, usally toe is wacked out. I wouldn't touch the bars for just a picture, it's a pain taking it back to the shop for an alignment. Go to post #61 and you'll see it in action, flexing without load. The added leverage of the Rancho arms allowed the stock t-bars to allow for compression even when the front was not under load. Street ride was as you can imagine a little on the soft side so I put the OME bars in. Yeah cv angles are steep but hold just fine, I keep that in mind when I'm wheeling. It's def. not a setup for everyone, and probably not worth the trouble and time but it works for me since I run trails for stock trucks....its just easier now.
Old Mar 21, 2007 | 01:04 PM
  #122
deathrunner's Avatar
WOW! pretty good even with the stock tbars. I would have kept them in there.
Are those the stock outer cvs? Hell, if they don't bind, go for it!
Old Mar 21, 2007 | 01:22 PM
  #123
86Original's Avatar
Originally Posted by drew303
flex? IFS? thats possible? HAHA
seriously...
<snip>
I have BJ's and aftermarket torsion bars and I've found the limits of the stock IFS. You can only have the arms drop so far before you experience axle binding. Infact, with stock upper bumpstops with BJ's (1.5") the axle binds. So I had to fab in larger upper bumpstops to limit the down travel.. Almost making the BJ's pointless. Though the truck sits higher, it doesnt flex ANY better.
<snip>
Aftermarket T-bars tend to be too fat to have any flex with the factory A-arms. I tried the SAW 26mm bars for a couple of months and went back to the factory bars so I could have better flex. They probably work great with longer arms. YMMV.
Old Mar 21, 2007 | 01:25 PM
  #124
mastacox's Avatar
I had good results with 1.5" BJ Spacers, Downey 26mm torsion bars, and swaybar disco's. Definitely stiffer than stock, but a good match for the Downey 1.5" HD rear lift springs.
Old Mar 21, 2007 | 02:45 PM
  #125
91ToyTrck's Avatar
Quick Shock Question :
When doing a u-bolt flip kit you are still remounting the bottom shock brace to the front of the axle (driver) and rer of the axle (passenger). Does this mean it's going to limit flex from one side to the other? I have never heard of such a thing.
Anyone? Explain Please
Old Mar 21, 2007 | 02:57 PM
  #126
LTrunner's Avatar
not sure...i did a u-bolt filp and went with sky's relocator kit...simple and effect puls very good for flex. shocks were moved to this kind of angle / \.
now all i got to do is put the chevys springs in
Old Mar 21, 2007 | 03:31 PM
  #127
91ToyTrck's Avatar
LT ~ What did you use to mount the top of the shock? pics iff possible? Did you have to move anything on top of the axle such as the e-brake or brake cables? How close did and when did you mount the lower shock mount?
Old Mar 21, 2007 | 03:37 PM
  #128
NorCal4Runner's Avatar
I'll play as well.
All stock.
Old Mar 25, 2007 | 07:48 PM
  #129
faubrunner64's Avatar
hey what the hell ill play too!
this is stock suspension with sway bars connected:
Old Mar 25, 2007 | 10:19 PM
  #130
Five1Nine8Eight's Avatar
Do 2wds count?
A couple inches from full flex:
Old Mar 31, 2007 | 01:44 PM
  #131
operose's Avatar
Just went out and played around a bit yesterday.
Here ya go!
stock everything
Old Mar 31, 2007 | 01:56 PM
  #132
drew303's Avatar
My truck came with the rancho torsions. They are stiff. I got a set of OEM ones with the new frame i just picked up. I'll probably leave them on so i can flex more.
right now my IFS is horrible.
seen some decent flex in a few rigs so far =)
Old Mar 31, 2007 | 08:33 PM
  #133
tc's Avatar
tc
Stock torsions, ProComp ES3000's, Eibach rear springs, no front swaybar, rear swaybar attached.
Old Apr 2, 2007 | 01:20 PM
  #134
Sonofmayhem's Avatar
Troy just won
Old Apr 2, 2007 | 01:41 PM
  #135
91ToyTrck's Avatar
TC - Besides being my reason for sticking with IFS ... How do you like your ProComp shocks? I haven't really heard anyone talk abour them around the boards. You hear Rancho, OME, and Bilstein all day long.
I agree ... TC wins!
Old Apr 2, 2007 | 05:52 PM
  #136
tc's Avatar
tc
I didn't know it was a contest either ...
As for the shocks, they are OK - nothing special really. They ride pretty nice both on and off road, but since doing the front bumper they are a little floaty. I think they run a little short, actually. If/when they wear out or I finally break down and install a lift, I'm going to spend a lot of time measuring and researching for their replacements.
Old Apr 2, 2007 | 06:16 PM
  #137
OFRD_GRL's Avatar
3" skyjacker performance strut lift
front and rear swaybars attached
33" baja claws
Old Apr 2, 2007 | 06:20 PM
  #138
tc's Avatar
tc
Keep trying Una.... LOL
Molly runs 35's - what size tires does Pete have?
Old Apr 2, 2007 | 06:21 PM
  #139
OFRD_GRL's Avatar
iunno LOL
i think 33"s
Old Apr 2, 2007 | 06:22 PM
  #140
OFRD_GRL's Avatar
and for the record i coulda gone further up pete.. but fj and pickup woulda had metal on metal action LOL i was CLOSE AS HELL to his back bumper
