Idle Problems
Old Nov 26, 2008 | 08:36 PM
LukeWilson's Avatar
Idle Problems
I have a 1990 22re pick up with 95000 miles on it. The problemo is when i am driving and press the clutch in it idles high, if i tap the gas it will usually return to the right idle. I don't have a tach so i don't know for sure but im guessing if its supposed to idle around 800rpm it would be idling at 1300rpm. I cleaned the throttle body the other day with no results and checked to see if the cable was hanging up on anything. The cable moved freely with no obvious problems. I am just wondering if anyone has had any problems similar to mine so i can be looking in the right places when i dive into it.
Thanks in advance,
Luke
Old Nov 26, 2008 | 08:41 PM
874runnersr5's Avatar
Try pulling the codes, it could be your mass air flow or you tps.
Old Nov 26, 2008 | 08:42 PM
anotherjeff's Avatar
Check the Throttle Position Sensor. (Retrieving codes is a good suggestion!)
Charecter1
Nov 6, 2023 10:08 AM
Eggslinger
Jun 8, 2019 03:32 PM
Alex Bessinger
Aug 31, 2015 09:17 AM
kyletbert
Jul 17, 2015 11:39 AM
Jnkml
Jul 6, 2015 01:20 PM
