idle air control valve question??????
Old Oct 21, 2013 | 12:50 PM
medicman's Avatar
I have a 91 toyota pickup 2wd, 22re, standard tranny. I had the iac off the other day to clean and test it my question is should you be able to blow thru both of the nozzles(hose fittings) on it? Mine I can only blow thru one fitting and I tried to even use an air hose on the other but nothing will go thru it so I didn't know if this was the way it was suppose to be or if its stopped up. I aint real up on the function of the iac but isn't coolant suppose to flow thru it? Thanks for any help.
Old Oct 21, 2013 | 05:51 PM
BigBluePile's Avatar
https://www.yotatech.com/forums/f128...-22r-e-228223/
Old Oct 21, 2013 | 06:16 PM
Teuf's Avatar
Blue, you dah Man..........
Old Oct 22, 2013 | 11:03 AM
osv's Avatar
osv
Originally Posted by medicman
I have a 91 toyota pickup 2wd, 22re, standard tranny. I had the iac off the other day.
somebody correct me if i'm wrong here :-0 your '91 did not come from the factory with the piece that bigbluepile shows in the pic, so someone must have swapped something out.
you should have the superior straight plenum/throttle body combo, that uses a mechanical system, here are the differences:
https://www.yotatech.com/forums/f116/iac-valve-226680/
Old Oct 22, 2013 | 02:28 PM
MudHippy's Avatar
...isn't coolant suppose to flow thru it?
Yes, it is.
Do you guys see how I did that? It's called answering a specific question specifically.
Better luck next time!
Old Oct 22, 2013 | 04:22 PM
Oh you're so clever......
smthwsn357
May 1, 2024 07:28 AM
Charecter1
Nov 6, 2023 10:08 AM
Eggslinger
Jun 8, 2019 03:32 PM
coryc85
Sep 9, 2015 06:24 AM
Avenged
Jul 9, 2015 07:55 AM
