Identify these Coolers Please!
Old Nov 4, 2021 | 02:42 PM
brycetryce's Avatar
Can anyone ID these coolers? I'm guessing that the larger cooler is the a/c condenser but I am not sure what the small rectangular one bolted to the front of the condenser is. Looking to replace both of these eventually and couldn't find anything online. Also, if I don't currently have the rest of my a/c system installed can I just leave these off for now and still drive? Thanks all!
Old Nov 4, 2021 | 04:08 PM
scope103's Avatar
Aren't the two condensers (a narrow one and a wider one behind it) just hooked in series? I have no idea if they are stock in any configuration (it doesn't really look like after-market plumbing), but presumably someone figured you needed more condenser cooling.
Can you "leave them off"? Not if you hope to ever use the rest of the A/C system in the future. Unless you securely cap the open lines, you'll get air, water and crap in the lines. Once that makes it to the compressor you won't be happy.
Old Nov 4, 2021 | 04:54 PM
rsmdon's Avatar
That is the same setup as my 1988 4runner. I think they used 2 condensers for more capacity because there is no electric fan for the ac. The 2nd gens have 1 condenser and an electric fan. If you do need new ones try rockauto.
Old Nov 5, 2021 | 07:38 AM
Jimkola's Avatar
YT Community Team
5 Year Member
Weird, can't find that shown anywhere on schematics. Can you post the model#? its on the vin plate on the door jam, or on the plate under the hood mounted on the firewall.
Old Nov 5, 2021 | 01:38 PM
rsmdon's Avatar
Your picture looks like 3.0 v6. My 1988 v6 ia avzn61lg-msea.Sorry jimkola not your picture.
Old Nov 5, 2021 | 02:07 PM
Jimkola's Avatar
YT Community Team
5 Year Member
Yeah, I guessed 1988 v6. But none of the parts diagrams show that secondary condenser. Not often I can’t find a part number for something oem.
Old Nov 7, 2021 | 12:32 AM
86 TOY's Avatar
The condenser pictured in the first post looks like the one Denso says is the OEM replacement (model #477-1033) for 4runners. It's available on to buy new on eBay and AutoZone.
https://www.autozone.com/cooling-hea...33/1115742_0_0
https://www.densoproducts.com/denso-...efv=2346265444
Old Nov 7, 2021 | 08:41 AM
Jimkola's Avatar
YT Community Team
5 Year Member
Ah, it’s one piece! I thought they separated.
Old Nov 7, 2021 | 09:29 AM
old87yota's Avatar
Yes, the condenser is all one piece.
These condensers with the extra little condenser in front of the main condenser were used in 4Runners up to 1989. The extra little condenser added more capacity for the A/C system to expel heat, which allowed the A/C system to absorb more heat from the cabin. Toyota did this because the cabin of the 4Runner is much larger than the regular or Xtra cab trucks and needed more cooling capacity. The Trucks just came with the main condenser.
Denso still makes these condensers new.
https://www.densoproducts.com/denso-...3-ac-condenser
Edit: I don't think Toyota ever showed a diagram of the 4Runner condenser, they just used the diagram for the trucks and listed a different part number for the 4Runners.
I believe the 4Runner condenser part number is 88460-89110.
Toyota has discontinued these from their parts offerings, even though Denso still makes them.
Old Nov 7, 2021 | 01:46 PM
wallytoo's Avatar
skjos
Aug 30, 2014 07:20 AM
FogRunner
26
Jul 7, 2010 09:27 AM
yotafied
Feb 8, 2010 09:09 PM
BajaRunner
27
Aug 30, 2007 11:56 AM
GREEN4SKIN'R
Jul 5, 2006 04:53 AM
