Identify a replacement part & earn $
Old Apr 20, 2015 | 01:22 PM
  #61
Minerbob's Avatar
CSOUT said: Bump for this thread to let you guys know you helped out another yotatech member. Just received and installed the two seals:
90304-76005(MAIN) CV SIDE
90316-60004(SUB) KNUCKLE SIDE
Fit perfect on my '90 SR5. And this says it all...
Old Jul 20, 2015 | 01:34 PM
  #62
Lybrium's Avatar
Hello all! I'm looking for the part number for the heater control valve for a 92 Pickup 3vze. It's a denso part, that's all I know, thanks! Ohh and Toyota wants 200 for it, this is crazy...
Old Jul 20, 2015 | 03:09 PM
  #63
dropzone's Avatar
Fossilized
http://www.toyodiy.com/parts/
Old Oct 16, 2015 | 01:21 AM
  #64
jtea's Avatar
High pressure steering hose assy.
Originally Posted by dropzone
Hello Gents,
Newbie Ol' Dude here and I have hit the wall! Hoping some one can help!!
MY TRUCK: 1994 "cherry" T100 3L V6, nearing 200 Kmi
MY PROBLEM: High pressure power steering hose assy has begun to
bleed fluid at the crimped end nearest the pump. FYI - - -> The original
hose assy is Gawd awful [short U-shaped metal pump connector, 2 ft.
rubber hose center section, 3 ft metal (multiple weird bends) section
connecting to the steering sector on the other side of the engine].
After reading much of this site's info and checking NAPA, Rockauto, Yota
dealerships, etc - - -> NOBODY has even a photo that matches my original
part!!! To top it all, local hydraulic hose assy rebuilders tell me that the
weird metal shapes will not fit their clamping machines. Yikes!
With so many of these T100's sold, I can't have the "Lone Ranger" T100.
Any info you may share would be greatly appreciated.
Thanks in advance,
JTea
Old Feb 6, 2016 | 09:05 PM
  #65
tazmaniac_37752's Avatar
Swiper
I believe what your talking about is called the swiper seal!
Old Feb 7, 2016 | 05:21 AM
  #66
MudHippy's Avatar
I believe you're wrong.
But then again...I don't know what you're talking about.
Old Sep 13, 2016 | 05:23 PM
  #67
ewong's Avatar
on a small bit of actual experience...
Long long ago (1991?) I could not get the Cir Clip on to the axle stub. and then just slipped the Cir Clip on and bolted it all back together.
I assumed, like others, that the "gold bolt" at the end would hold things together.
Not So.
A long while later of driving mostly in 2WD (maybe 50K?) I found that the axle stub uses that cir clip to "float" the axle above the bronze bushings that are inside the spindle.
The Stub Axle "egged" out the inner bronze bushing (the one at the engine side of the spindle).
It also then "rode" on the outer "cog" bit of the manual hub. Basically ruining the part.
(Now a days there are replacement parts).
I then swapped over the WARN manual hubs (but later swapped back to OEM IFS hubs)
Anyway - the "broken" Aisin hub is a beloved paper weight on my work office desk...
Old Dec 31, 2016 | 01:32 PM
  #68
blueknob's Avatar
Identify this part
These came in a gasket kit and i don't know what there for
Old Dec 31, 2016 | 01:47 PM
  #69
millball's Avatar
They are exhaust manifold and exhaust piping sealing rings
Old Dec 31, 2016 | 01:55 PM
  #70
blueknob's Avatar
Old Mar 18, 2017 | 03:51 PM
  #71
silentsod's Avatar
Would anyone happen to know the part # for the door trim clip which is nearest to the HVAC vent and side view mirrors? I managed to snap the retaining pieces on my driver's side today. They look like these: http://www.ebay.com/itm/Toyota-Picku...=Make%3AToyota but the listing does not have a part # and I need the -J0 color not -B0.
Old Mar 21, 2017 | 06:37 AM
  #72
magnet18's Avatar
I don't have the part number, sorry, but one of the things my local dealer was actually good for was a variety box of misc. clips like these. Come in handy more than once.
Old Jun 28, 2017 | 07:58 PM
  #73
Clifford1990's Avatar
I was wondering if any of you all could identify this sensor right here.
It appears to have been ripped out while moving parts around.
Old Jun 28, 2017 | 08:13 PM
  #74
millball's Avatar
22re right??? Knock sensor.
Old Jun 28, 2017 | 10:11 PM
  #75
Yes, 22re.
Here is another picture to be safe. A quick Google search of threads showed that it's around the oil filter, but I want to be sure.
Also a Google search brought me to this Amazon link - Worth it?
Amazon Amazon
I'm not used to buying parts online and I don't know where else to look.
Old Jun 29, 2017 | 07:17 AM
  #76
magnet18's Avatar
That Amazon link is just the wire, not the sensor
If you broke the sensor, it might be hard to find a new one, might need a parts yard trip
Old Jul 14, 2017 | 08:47 PM
  #77
Thank you all so much.
I have another mission for y'all.
Old Jul 14, 2017 | 09:01 PM
  #78
se7enine's Avatar
Cold Start Injector Time Switch?
Old Jul 15, 2017 | 05:39 AM
  #79
gsp4life's Avatar
+1
And the green one next to it is the engine coolant temp sensor (not for the dash gauge)
Old Jul 15, 2017 | 12:25 PM
  #80
Cold Start Injector Time Switch....is that a different name for Thermo Time Switch?
When looking around I get the above name more often.
Such as this
With the black one looking very similar to the one I'm looking for
2nd edit: I have found the product on various websites in case anyone was looking for it.
http://www.lceperformance.com/OEM-22...-p/1067011.htm
http://www.partsgeek.com/ss/?i=1&ssq...switch&x=0&y=0
http://www.autopartswarehouse.com/sk.../158-0484.html
