IACV port in TB
Old Dec 31, 2012 | 10:33 AM
lilgription's Avatar
Question IACV port in TB
I know some on here have taped the port to cure the idle surge problem. Has anyone permanently blocked that port if they didn't resolve their idle surge? If so what effects could it cause down the road? And does changing seasons affect it; hot- cold etc.
Old Dec 31, 2012 | 05:18 PM
Co_94_PU's Avatar
I don't have surge issues, but have a read thru http://www.autoshop101.com/forms/h60.pdf
"Depending on system type and application, the IAC system may perform a combination of the following control functions; initial set-up, engine startup, warm-up control, feedback idle control, engine speed estimate control, electric load idle-up, learned idle speed control, and A/T idle-up control."
It goes on abit further and mentions
"Effects of IAC Operation on Emissions & Driveability
If idle speed is too low, the engine may stall or idle very rough. If idle speed is too high, harsh A/T gear engagement may result"
I think it's the non ecm type, refered to as a "wax air valve", used for these models? ( I remeber reading something about the wax... )
Old Dec 31, 2012 | 05:57 PM
Good link there. I may have to pull mine apart and try a good cleaning
kawazx636
Oct 6, 2021 03:03 PM
LittleUgly
15
Jan 2, 2020 01:30 PM
Ditch Doc
Oct 27, 2015 03:20 PM
alexcarey
Oct 14, 2015 06:05 PM
old87yota
Sep 9, 2015 12:39 PM
