I got nothin'!! 22re wont start after top end rebuild
Old Aug 27, 2010 | 04:30 PM
4xEnthusiast's Avatar
So, over the past week or so, I have been rebuilding the top end of my '89 pickup 22rE... While disassembling it, I was sure to label the hell out of EVERYTHING. Everything is back where it belongs, connected correctly, and torqued and installed correctly... I just went for the initial startup... And I got nothing but starter noises and spark noises... Any suggestions???
One thing that I thought may be an issue is the fuel lines going to and from the fuel filter... While disconnecting them to install a new filter, I found how difficult it was to correctly gauge where the holes in the bolts were comparable to the fuel lines... Could the issue be that they are not lined up correctly?? Someone please help...
Old Aug 27, 2010 | 04:32 PM
2DoorRunner's Avatar
So is the started engaging?
Old Aug 27, 2010 | 04:33 PM
Yes, the starter is engaging and the spark plugs sound like they are firing.
Old Aug 27, 2010 | 04:39 PM
Check spark. Then if thats good move onto the fuel system. Just dismiss one part at a time.
Is your MAF sensor plugged in?
Old Aug 27, 2010 | 04:46 PM
92 TOY's Avatar
is it cranking? or is the starter just clicking?
Old Aug 27, 2010 | 04:48 PM
MAF sensor is plugged in, and how do I positively check the spark?
Old Aug 27, 2010 | 04:49 PM
It's cranking completely, crankshaft turning, fan turning, belt moving completely, just no engine start...
Old Aug 27, 2010 | 04:55 PM
yoder519's Avatar
so its tryin to start, just not turning over correct? im sure you did, but is the timing set right?
Old Aug 27, 2010 | 04:57 PM
Yes, it is trying to start, everything is cranking, but it will not turn over. I believe now, after looking at it more, that it may be a fuel issue... There is no fuel making it through the lines on my throttle body. The furthest along that fuel is showing presence is at the junction between a fuel line and my upper intake.
92 TOY's Avatar
coil wire back on?
Old Aug 27, 2010 | 04:58 PM
Oh, and yes, the timing set right. Everything is lined up correctly.
Old Aug 27, 2010 | 05:00 PM
Coil wire is connected.
Old Aug 27, 2010 | 05:03 PM
yoder519's Avatar
is the fuel filter on correctly? its realll easy to put them on backwards from my experience.
Old Aug 27, 2010 | 05:05 PM
Would the fuel not get past the filter if it was on backwards? Because from what I can tell, the fuel is getting past the filter and up to my EFI body but then seems to cut off there.
Old Aug 27, 2010 | 05:09 PM
In research, it seems as if that wouldn't make a difference as to whether the fuel would move through it. Not saying that isn't on backwards, but that doesn't seem like what is causing my current issue.
Old Aug 27, 2010 | 05:13 PM
I dont know about the filter youre using, but some (if not all) are directional, may as well put it on the right way just to be sure.
Fuel will still flow through it, just not as well.
Have you ever taken one off and shaken it. Fuel comes out one side easier than the other.
So that may be why you arent getting enough fuel to the motor. The pump might just not have enough psi to push it through the backwards filter more than a little bit of fuel at a time.
Old Aug 27, 2010 | 05:29 PM
Alright. I will have to try that...
Stick with me here and see if this makes sense to you... There is a fuel line that comes from under the upper plenum and into the side of the EFI chamber... This is the furthest that my fuel is getting... I believe that it may be clogged and fuel isn't getting through the piece mounted to the side of the EFI body. However, I may be talking out of my ass and have no idea what I am talking about...
Old Aug 27, 2010 | 05:31 PM
takeitoutgetitdirty's Avatar
Crack the CSI Line to see if fuel comes out. If you have fuel getting to the the injectors than check that the ground is hooked up to the intake. Check all fuses and relays. If thats not it check the wiring harness for broken injector wires.
Old Aug 27, 2010 | 05:32 PM
yoder519's Avatar
maybe you just got air in the fuel lines or something? jsut a suggestion, im not even sure if that can happen..
Old Aug 27, 2010 | 06:00 PM
All fuel lines, connected to the fuel rail and injectors have no fuel in them... A friend suggested that my timing may be off......
