How would you run dual Exhaust?
Old Aug 20, 2008 | 10:25 PM
Matt16's Avatar
Why not just make a sound recording of a 350cu Chevy and play it through your radio or headphones.
Old Aug 21, 2008 | 12:43 AM
stormin94's Avatar
I have the headers, and I run single exhaust. If you really wanna be cool, you can just split it at the muffler, and have two small outlets, or just mount another exhaust tip on the other side, but that can be your little secret.
Old Aug 21, 2008 | 12:59 AM
DilutedImage's Avatar
Whatever you decide on, use equal length pipes from the headers to the junction (Y, X, H, whatever).
Old Aug 21, 2008 | 07:34 PM
Strings's Avatar
I guess I'll have to split it after the muffler. DilutedImage why is it important to run equal length tubes to the junction?
Old Aug 21, 2008 | 07:53 PM
  #25
space-junk's Avatar
Prolly because it wont work the way that it is intended for...
i.e. the scavenging...
Old Aug 21, 2008 | 09:05 PM
  #26
Alex 400's Avatar
yes, by having different size tubes it will put a different amount of back pressure on each side of the engine, making each side run a little different.
Old Aug 21, 2008 | 09:22 PM
  #27
abecedarian's Avatar
regardless of the length of tubing on one side or the other... being equal length isn't really that important... the important thing is to have an exhaust pulse from one 'header' pass the pipe from the other 'header' when the pressure in the other pipe is lowest, that way the pressure pulse draws (creates negative pressure) in other pipe, sucking the exhaust out (a.k.a. scavenging)
so you end up dealing with velocity, which means you want the smallest diameter pipe that can flow the gasses without restriction (any larger diameter would slow the gas velocity down).
it's not exactly rocket science, but the side with the longest run to the 'y' will have a smaller pipe entering the other pipe's stream in order to keep velocity at a maximum, and consequently enhance scavenging.
Old Aug 22, 2008 | 03:04 AM
  #28
gte718p's Avatar
Originally Posted by BAMF_CT2004
so let me get this straight. You are will to spend, im sorry, waste money to achieve 1/2 hp out of a 3.0.. maybe.
Dude, its not a chevy
Actually that's should be you want to waste money to lose HP so you can sound cool.
Go buy a Chevy. You need backpressure. You would end up with two 1 inch exhaust and unless you did the cross over right lose significant HP.
Old Aug 22, 2008 | 04:07 AM
  #29
91 4Runner's Avatar
If it's sound you want, here is a muffler for you.... (I know it was for a hope of performance not sound)
http://store.summitracing.com/egnsea...9&autoview=sku
And if you don't end up liking it you can always pluf it again...
Old Aug 22, 2008 | 03:17 PM
  #30
CoedNaked's Avatar
If you want to run duals, I'd run 2" Mandrel bent pipes, MAX, coming off of each side and keep it 2" the entire way. The other thing you might want to consider is run the 2" pipes right beside each other after the X-pipe - the hotter you keep the pipes, the better the exhaust gasses will move.
Old Aug 22, 2008 | 03:57 PM
  #31
Alex 400's Avatar
whoops i thought you meant size of tube. sorry length shouldn't really matter
Old Aug 22, 2008 | 04:37 PM
  #32
You mean DOM (drawn over mandrel) not just mandrel bent? All exhaust shops use a mandrel to bend the pipes.
And you may consider the passenger side crossing over to the drivers side, dropping from 2" to 1.875 (1 7/8" about 3/4 of the distance to the drivers side, just to keep velocity up), then dumping into the 2" from the drivers side at about a 60 degree angle.
Old Aug 23, 2008 | 09:59 AM
  #33
Strings's Avatar
Well you guys have convinced me to run single exhaust. Atleast until my yota acquires 2 more cylinders!!!
Old Aug 23, 2008 | 02:45 PM
  #34
CoedNaked's Avatar
I've never heard that. Everything I've heard is mandrel bent or pressure/crush bent (with only few and far between exhaust shops ponying up the money to have an onsite mandrel bending machine). The former being the bends have the same diameter as the straight sections of the pipe, the latter being the bends are crushed to an oval/restricted type of pipe at the bends in comparison to the straight sections. The former having better flow & less turbulence because of the mandrel bends, the latter having the opposite.
Old Aug 23, 2008 | 03:59 PM
  #35
RunnerUp's Avatar
i wouldnt do it, though i personally dont like the look of duals on trucks that dont come stock with them... but if your going to do it, do it right, and do it once.
Old Aug 23, 2008 | 04:36 PM
  #36
algranger's Avatar
if you want the looks you could put a y pipe at the very end of a 2.5" system then youd get a bit of good sound. i always liked the look of the pre rear axle exit pipes at kind of a downward angle with some raw edge angle cut chrome tips like these
edit: but not 4" like that one ^ it might make you look like a bit of a dumbass
Old Aug 23, 2008 | 05:15 PM
  #37
just a 22re's Avatar
i say go with a 1.75in pipes and everything from the headers back!!
Old Nov 30, 2009 | 08:38 AM
  #38
91_TOYOTA_4x4's Avatar
just split it at the muffler if you want duels, it will just be a pain if you try and make it true duel.
listen to this, sounds amazing
[youtube]http://www.youtube.com/watch?v=pGZVVRyuQN0[/youtube]
Old Nov 30, 2009 | 08:50 AM
  #39
MaK92-4RnR's Avatar
thats not dual exhaust.... thats dual inlet to a single outlet.... my system can easily be set up for true dual exhaust, but I didn't want to go that route. Heres a couple pictures, to show everybody.
Old Nov 30, 2009 | 08:53 AM
  #40
o in know haha just showing how it sounds without duels and how awesome it can sound. no point in duels if you can get it to sounds as good as this.
the1998sr5
15
Jul 14, 2020 08:35 PM
hexrain
Jul 12, 2015 01:13 PM
Coreyr384
Jul 10, 2015 11:13 AM
crashburnoveride
Jul 10, 2015 06:39 AM
toyoda8488
Jul 5, 2015 10:18 PM
