HOW TO: Remove the Oil Pan on a 22re 4wd
Old Apr 22, 2010 | 05:38 AM
  #61
Lumpy's Avatar
Good job Jerry...and Joe get an "atta boy"!!!
Old Apr 22, 2010 | 08:11 AM
  #62
92 TOY's Avatar
tanx LUMPY.
Ok....so now that I can say that this method DEFINITELY WORKED, I will finish (kinda) with pics of the end of this little "sub" project.
Old Apr 22, 2010 | 08:23 AM
  #63
92 TOY's Avatar
lined up the front driveshaft
hand tightened the bolts...using the painted matchmarks
started to raise the diff
it bound up on the driver's side
brought out my "friends" to help it change it's mind
but then thought again about that and began to make small adjustments with the jacks underneath. little by little the diff mounts moved closer to where they were supposed to be.
got the driver's side close, but not enough....was able to make some small movement with my hands pushing and pulling on the "axle tube" (as i will call it)...with that, i was able to get the driver's side mount mostly tightened down.
on to the passenger's side....this one you have to do blindly, using your hands as your eyes. using a long screwdriver (from the toolkit, minus the attachment) i was able to get the hole mostly lined up as well. after a few good guesses as to how to "convince" it to move where i need it to go, i was able to bolt this side too. again, snug but not altogether tightened down just yet.
took a break, and then right back to it.
got out the old petroleum jelly...because i knew it's a metal-on-metal game getting this crossmember on, so i applied it to every mating surface.
almost there..........
getting that sideways bolt in proved to be a bit of push-pull-up-down trying to get so the bolt would pass right through....it did, and with it's special nut, properly placed, i tightened it and the 4 other bolts down.
have to find the torque specs in the FSM and troque everything down now.
Old Apr 22, 2010 | 09:03 AM
  #64
Lumpy's Avatar
Good going man!!!
Old Apr 22, 2010 | 09:10 AM
  #65
92 TOY's Avatar
front bolt that goes side to side...108ft/lbs.....and alot of UMPH.
Old Apr 22, 2010 | 12:53 PM
  #66
highonpottery's Avatar
man...you went through all that work and time and didn't clean all the gunk off before reassembling?
Old Apr 22, 2010 | 01:01 PM
  #67
92 TOY's Avatar
if you mean the pan, i killed the paint on the pan yesterday.
if you mean the diff...that's getting the treatment AFTER i'm up and running.
Old Apr 17, 2012 | 06:57 PM
  #68
trktwo's Avatar
Tagged
Old Apr 17, 2012 | 08:54 PM
  #69
yotarover's Avatar
if you had a body lift say 2" you could use a engine hoist to lift up the block. take off the bolts for the mounts and jack up a lil more. than the stock height for the body. after that taking out the oil pan is easier. did it on my 89 with a auto.
bigjstang
Jun 2, 2025 03:56 PM
Colington
Mar 8, 2020 09:51 AM
mskalmus
May 28, 2017 07:51 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
HRDC0R19
Jul 5, 2015 06:43 PM
